need help quick/ turn signals bad
Ok so if i press my hazard light the only turn signal that works is the front passenger side, Then the switch will glitch and make a strange sound. Also only the right arrow will work on the gauge cluster. All normal lights turn on and work just no flash. Any ideas?
I had a blazer that did something like this. The turn signal lever with the window washer controls went bad and needed to be replaced. Hopefully that isnt the issue cause those can be quite expensive. Good luck.
TfcCDR
09-14-2015 12:08 PM
