sluggish ...out of ideas
ok
95 3.8 - 5spd
i originally had a real rough idle and after getting some help and searching the forums i took care of that.
now however i am having a real problem with the car being sluggish all the time.
when i bought the car i replaced (out of habit)
air filter
plugs/wires
belts
and fluids....just my typical welcome to the collection treatment.
then i went on to replace the vacuum lines, maf (cleaned), fuel filter
camshaft pos sensor (had code) and pcv....and tried fuel cleaner in tank.
now that the idle has leveled out i have this problem.
it happens no matter engine temp, or gear
i also notice what sounds like a misfire and a rich smell.
having poked around i noticed that maybe cats could cause this (blockage)
i am also about to replace the charcoal canister behind fender, noticed fuel smell coming from pass. front. when car is just sitting in garage.
i know thats alot to take in but thats where i stand.
any help would be appreciated.
95 3.8 - 5spd
air filter
plugs/wires
belts
I know you say that the smell is coming from the front pass side but check and see if you are leaking any gas at the filler tube (where you put gas in). The gaskets have a tendinsy to crack and leak fuel after a fill up, or after a hard turn and all the gas sloshes around. If its not that check the fuel lines under the car to see if they might have sprung a leak.
As for the idle issue. My 95 has a small but noticible rough idle that doesnt go away but that I only see/feel when im not in gear (red light, stop sign). If i leave my hand on the shifter I feel like I have parkasins (spelling??), it shakes that much. I once read in a Mustang book (cant remeber which one, wish I had bought the damn thing) that all 1994-1995 had a "mid engine shake that Ford could not get rid of"....
Matthew
Matthew
