98 Mustang V6 fuel problems
Greetings everyone! I have been searching all over trying to figure out what is going on with my mustang, and hope that the members here will have a clue. Here is what I am experiencing.
Recently my mustang has been "bogging down" when trying to pick up speed if I press the pedal too hard. If I take it slow, it will pick up and get to driving speed eventually, but it takes a while (about a mile or so it seems). When the car is in park and running, I can press the accelerator and it seems to pick up alright, but will not do so on the road under a load. It will also bog down when going up a hill if I try to keep the constant speed. I have replaced the fuel filter, which when I drained it, there was considerable sediment in it. I have read that there could be power problems or fuel pressure problems, and I'm pretty much at a loss as to what I should do or which way I should go with this. Any and all assistance you can provide would be greatly appreciated. Thanks!
My first guess would be either bad spark plugs/wires or the ignition coil is bad. I'd start with the plugs/wires if you haven't changed them out in a while.
But if you want to check the fuel pressure, most auto parts stores will rent a fuel pressure gauge that you can connect to the Schrader valve on the fuel rail. There are a ton of video's on how to run a fuel pressure test on youtube.
Good luck...
Good luck...
KingRando
10-02-2015 08:06 AM
mrappe
09-26-2015 10:16 AM
