Old 10-20-2015, 10:30 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
Replace Door Hinges
Old 03-07-2011, 01:09 PM
MWSTANG99
MWSTANG99's Avatar
Default Replace Door Hinges
All,
I am in the middle of replacing the drivers side door hinges on my daughter's 1999 mustang comvertible. I removed the front fender and replaced the lower hinge but would like to know if anyone has a tip on how to get to the inside nut on the upper hinge. Can I get to the nut if I remove the gauge cluster. It doesn't appear that the top of the dash comes off so if I can't get it through the gauge cluster I might have to remove the entire dash which I really don't want to do.
Any help would be appreciated.
Thanks,
MWSTANG99
MWSTANG99 is offline
Old 03-08-2011, 11:24 AM
robb15033
robb15033's Avatar
+1 Please.
I have a box sitting here with new hinges for my drivers side door. I would like to know what I'm in for. Is it straight forward? Using a jack and a second person to hold the door stable?
Thanks-
robb15033 is offline
Old 03-11-2011, 06:56 PM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
Uh, is the hinge damaged? Usually it's nothing more than hinge pins and bushings, a VERY cheap and easy repair with any half capable extra pair of hands.
RyansQuick6 is offline
Old 03-12-2011, 03:23 AM
robb15033
robb15033's Avatar
No, Its complete hinge replacement. Top and bottom.
I have been asked if it has pins and bushings several times in the past when someone notices that its sagging a bit. It has two hinges each door.
Old 03-13-2011, 09:24 PM
RyansQuick6
Reverse Gear Member
I'm trying to tell you to not replace the whole hinge unless it was damaged, 99% of the time it's just pins and bushings, but of course there's always that chance. Just make sure you mark everything very well or you'll play hell getting the door to line up.
Old 03-14-2011, 06:46 AM
MWSTANG99
MWSTANG99's Avatar
Ryan,
I replaced the lower hinge and gave up on replacing the upper hinge because it looks like you would have to remove the entire dash to do it. I removed the gauge cluster and the headlight switch and still could not even come close to seeing the nut on the inside of the hinge. I would like to just replace the hinge pin and bushings if I could. That is what I originally wanted to do but I have not been able to find pins and bushings for a 1999 Mustang. I can find them up to a 1998 but not for the 1999 and up. Any suggestions. I would still like to replace the pins and bushing on the upper hinge. As is all I did was adjust the hinge to take up the slop so the door closed correctly.
Thanks in advance.
MWSTANG99.
Old 03-14-2011, 12:03 PM
robb15033
robb15033's Avatar
Please correct me if I'm wrong-(might be, was told otherwise by Ford)
The 94-98 Mustangs do not have the pins and bushings. They are one piece that has to be replaced. No parts that can be replaced/repaired.
You know a million times more than me in regards to our cars, so I'll wait to hear from you. I don't have a clue to tell you the truth, but I do have 2 new hinges here in a box to go on the car.
Old 03-14-2011, 12:05 PM
robb15033
robb15033's Avatar
Originally Posted by MWSTANG99
Ryan,
Thanks in advance.
MWSTANG99.
Thanks mwstang99 for your updated post and I'm sorry if I am getting in the way. It is your original posting-
Old 03-14-2011, 08:04 PM
RyansQuick6
Reverse Gear Member
You can ONLY get them from Ford, and ONLY if you can find a competent parts man, and most likely all you need is a set of bushings, 8 total. Another option is using a dorman kit and slightly drilling out the bushing hole so that the larger Fox bushing fits. The hole needs to be about 31/64's, NO LARGER, and it will work perfectly.
Dorman site
http://www.dormanproducts.com/p-27583-38438.aspx
I found them for about $7 on amazon
Old 03-14-2011, 08:10 PM
MWSTANG99
MWSTANG99's Avatar
Ryan,
I did check at a Ford dealership for the pins and bushings and they told me that they were not available. That is why I ended up buying the hinges instead. I also checked with Advance Auto and they could not get the pins and bushings either. I will try a different dealership for the pins and bushings to see what happens.
Thanks,
MWSTANG99
Quick Reply: Replace Door Hinges
