PCM help please! Swapped out Engine & Transmission
I have a 2001 Convertible. I swapped out the engine and trans with a 2004 wrecked Mustang with low miles. I did not switch out the PCM.
The engine starts and idles fine, but when the car goes above 30 mph, the transmission does not shifts properly and the car lurches and would not accelerate properly.
Someone told me that the PCM needed to be reflashed or switched out. So I swapped out the PCM with the 2004 wrecked car. But, the car now won't even starts. The engine cranks but no ignitions at all.
I put back to the original 2001 PCM, the car starts just fine but still has the same transmission shifting problem.
Does anyone has any idea on how to fix this? Do I need to switch out the PCM harness and how difficult is that? Thanks for any inputs.
Confirmed with the dealer that the old key won't work with the new PCM and so the engine will crank but won't start because of the anti-theft system described above. They can reprogram the old key to work with the new PCM for $125. Will try that.
The trans does not seem to be damaged. Below 30 mph, the car drives fine, except that the speedometer is way off...showing like 80mph. Above 30 mph, the trans shifts up then down, and speedometer goes wild. Seems to be a communication problem. Several mechanics said the corresponding 2004 PCM must be used with the 2004 drive train. Made sense...since the 4 digits codes for 2001 and 2004 PCMs are different, TBX3 and CAX0 accordingly.
Did you stay with the same style trans? (Auto to auto swap?)
You need to retain the stock computer for the car - as posted - and not swap the 2004 computer in.
I'd say the trans you have is messed up or one of the sensors in the trans is shot. VSS would be the place to start since you mentioned the speed is reading way off.
Cannibal_carnies
03-02-2023 06:17 PM
HIS S-197
08-10-2015 05:47 PM
