I topped of the other day and noticed a puddle of fuel. Do the cars normally leak at the filler tube? I tried a search but really didnt find anything. Thaks for all the help
Mine was the seal between the neck and the tank, dropping the tank was a bit of a pain but it only took about half an hour and it hasn't leaked a drop since.
It's best to check it out before inspection time, if you have a rotted filler or bad seal its going to blow a code at sticker time. Rotted fill tubes are very common now although not so much in Mustangs. It's more common with cars like Neons or Buick Regals where the fill is located behind the wheel and alot of water and road salt kick up on it causing corrosion. Its easy enough to get a replacement fill tube, if not OE, you can get them off a supplier who deals in used fillers off of southern vehicles. My guess though is the seal.
i had the same problem , the seal at the top of the gas tank had to be replaced... o1 silver v6 3.8L mustang conv. that is the only problem i have had since i have owned the car.
same car has got to be the same problem. What did you do to fix the problem? I searched autozone, and other autoparts websites and cant figure out what part I need, Thanks in advance.
