High pitched squeal on startup
Old 09-20-2011, 04:33 PM
fred_720
fred_720's Avatar
Default High pitched squeal on startup
I have a 1998 ford mustang, 3.8L, and recently it stared to squeal really loud on startup. It was high pitched and just about disappears when I start driving it. I took it in to a mechanic and they originally thought it was the alternator/serpentine belt. So they took that belt right off but the squealing persisted just as loud as before.
They said they thought it might be the timing belt (even though its a chain, same difference i guess) which would require a lot of work and money. I didn't think that timing chains squealed like that so i'm wondering what else it could be. I don't want them to do $800 of work only to find out it isn't the timing chain.
Any ideas what it could be?
fred_720 is offline
Old 09-21-2011, 03:03 AM
petrock
petrock's Avatar
Good to hear your mechanic just throws parts at a problem instead of actually diagnosing it. I'd find a new mechanic. Just sayin'...
The squeel could be a lot of things. I'd pick up a mechanics stethoscope from your local auto parts store ($6) and poke around a bit. I'd suspect one of the pulley's that the serp belt runs around is bad. Also check the belt tensioner to make sure that it is providing enough tension on the belt. If its loose it can cause your squeal and other issue. When the vehicle is running, check if the belt tensioner is pulsating up/down. If it is, then its worn out. Good luck...
petrock is offline
Old 09-22-2011, 05:37 PM
03shadow
03shadow's Avatar
yeah a mechanic would jump to something that they will surely charge you at least a grand for. its most likely a pulley, like petrock said
03shadow is offline
Old 09-22-2011, 11:49 PM
neo8222
neo8222's Avatar
i say get a new mechanic just cause he can't figure out the difference between a over head VALVE and an over head CAM motor... timing belt on a OHV mustang.... dumba$$
also fyi the timing chains and belts are the same in the since that they both time the valve train to the rotating assembly but thats about where it ends.
neo8222 is offline
Old 09-26-2011, 08:05 AM
mustangmike09
mustangmike09's Avatar
so before the responses fail even more.
If they took the belt off and it still making the sound. Then its not related to the accessories. . . that was step 1 diagnostic.
You do have a timing chain, and its not that hard of a repair if that was the case FYI.
But id look into the CPS first. (Camshaft position sensor) this is a shaft that spins by a gear connected to the camshaft gear. It also has a shaft that runs the oil pump. These are known to somehow "go bad" and squeal as described. I would do some searching about that. If thats the case, very easy change.
mustangmike09 is offline
Old 09-26-2011, 09:47 PM
desertt5
desertt5's Avatar
The CPS is right behind the water pump. Just repalced mine last month. As mustangmike said, not a bad job change it out.
desertt5 is offline
Old 09-27-2011, 09:59 AM
du907
du907's Avatar
Does the CPS have to be positioned "just right" like a distrubitor would be since it is basically taking the place where a dist. would be if it was an old style motor? Or when replacing do you just unplug it take the retainer off put a new CPS in and plug it back up.
Just curious.
du907 is offline
Old 09-27-2011, 02:15 PM
scoltharp
scoltharp's Avatar
My 07 just started doing the same thing recently. It squeals right when it turns over but goes right away. Would this be the same thing?
scoltharp is offline
Old 09-27-2011, 06:55 PM
desertt5
desertt5's Avatar
Just curious.
Check here, It does need lines up before you pull the old one out.
https://mustangforums.com/forum/v6-1...-replaced.html
desertt5 is offline
Old 09-27-2011, 06:58 PM
desertt5
desertt5's Avatar
I guess it is possible. I would follow mustangmike's post to narrow it down.
desertt5 is offline
Quick Reply: High pitched squeal on startup
