Motor removal on a 3.8
Hi folks, I have the motor ready to come out on the son's '97 3.8 but I needs to attachment advice for the change. I have never pulled one of these with aluminum heads. Where is the best place to attach the chain?
I purchased a 6" x 13"x1/4" steel plate. I have drilled it to match the lower intake. I have then used a standard motor lift plate available at O'Rielly. I have drilled and will attach it to the other plate and use it for a lift point. I will take some pictures and let you know how it works. Total cost is less than $20.
Bob
Bob
Probably not the best, but we wrapped one chain around one of the exhaust manifolds and took the alternator out and threaded the other chain with the alternator bolt. It held well, however, and the bolt didn't buckle either.
jaiidutch
09-14-2015 10:29 AM
