Mach 460 new radio HELP!!!!
I have the mach 460 with original head unit, i removed that and had the wire harness and everything, but my colors do NOT seem to match up with what i have been finding online... I dont know which colors connect to what, this is what I have for my 8 speaker wires. (I need to know what each of them does)
Light Green
Light Blue
Light Blue / black stripe
White / orange stripe
White / red stripe
Grey
yellow
purple / white stripe
Light Green
Light Blue
White / red stripe
Grey
yellow
I have an aftermarket head unit hooked up to my mach460.. i don't know off hand what they go to, but tomorrow i will pull it out for you and tell you what i have hooked to what...i know my colors didn't match up correct either, but everything seems fine now, ALTHOUGH when using the balance on the head unit, adjusting to my rear, sound still comes out of the passenger door speaker, the tweeter is quiet, i am fine with that because i always have it at 50/50 F/R and 50/50 L/R but ill let you know what i have in the morning
Alright here we go, the colors are as follows
From Radio - To Harness
Red - Red
Purple - Grey
Purple/Black - Grey/Black
Black - Black (Duh)
Green - White
Green/Black - White/Black
Orange/White - Orange
Yellow - Yellow
Grey - Grey
Grey/Black -Grey/Black
White - Green
White/Black - Green/Black
For RCA Output - Amps (if you have the adapter)
Blue/White into 2 blue/white
Amp start into 1 black/white on radio harness and 2 into the amp harness
Hope this helps you
Red - Red
Purple - Grey
Black - Black (Duh)
Green - White
Yellow - Yellow
Grey - Grey
White - Green
Hope this helps you
Light Green
Light Blue
White / red stripe
Grey
yellow
those are my colors behind my radio, and we ran into another problem, we opened the speaer and everything and those wires are even MORE different colors, idk what connects to what and idk whats positive and whats negative
Light Blue
White / red stripe
Grey
yellow
yeah they are, and the driver side speaker we took out has 2 wires in (DUH) but they are different from the 8 wires going into the first radio! SO im really confused right now, any help would be reallllyyy great. thanks
