Replacing Ball Joint and Lower Tie Rod
Old 01-14-2012, 11:05 PM
Daytripper540
Daytripper540's Avatar
Default Replacing Ball Joint and Lower Tie Rod
Just purchased a new ball joint and lower tie rod end, to hopefully alleviate some of my car's squeaking and sloppy steering. I know I will need a special tool to take out the ball joint...but how hard is it to replace these?
Also, I will be buying another ball joint/lower tie rod for the other side once I get payed again. Should I just wait and do them both at the same time, or is it alright to do them one at a time?
Daytripper540 is offline
Old 01-15-2012, 08:46 AM
DRAGUL
DRAGUL's Avatar
Do them both at the same time. You may need to get a alignment done afterwards.
DRAGUL is offline
Old 01-15-2012, 03:18 PM
petrock
petrock's Avatar
may -> will. Messing with the tie rods always requires an alignment. You may get it close, but you'll never get it correct. Your tires can wear pretty quickly with an incorrectly alignment. Do both sides at the same time and get it aligned once. Good luck...
petrock is offline
Nick Oliver
10-17-2018 04:22 AM
Dragonus18
09-09-2015 01:21 AM
Luke9222
09-04-2015 06:46 AM
Emblazoned
09-03-2015 10:45 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Replacing Ball Joint and Lower Tie Rod
