Interesting problem..
I have a guy that is extremely knowledgeable with mustangs working on the car as we speak but I was curious and thought I would bring my question here.. It's an ongoing issue and was having some other stuff installed and the guy told me that for some reason the battery is not charging while the car is idling.. He said that if you rev it up it will start to charge but at idle there is no charging of the battery.. Just curious on what might cause something like this to happen..
I do have a system but its nothing major... And we just installed the hi output alternator.. I was having charging problems prior to this and when I had this guy install it he said he tested everything and for some reason it is not charging while at idle.. When you rev it up though it shows that its charging.. I just remembered that when I first got the car and did alot of work we installed an under-drive pulley.. Wondering if that might be part of the problem..
Yeah that would of been my next question is do you have under drive pullies. You said yes, and there likely lies the problem. The alternator is being under driven causing it not to charge at idel. You need to put the larger diameter pulley on the alternator.
I say No on the pulley idea. I've got the much maligned 42% motoblue, been running it for 5 years now. Still on my stock 99 alternator. Never had problem 1. I say corrosion on your wiring. Some fibers are dead inside the shrouding, that's why at idle not much juice is getting through. When you rev lots of extra energy is available and jumbling it's way through your limited available fibers.
