Power steering pump pulley removal
Old 03-02-2013, 10:49 AM
IronMan0002005
IronMan0002005's Avatar
Default Power steering pump pulley removal
I'm trying to remove the pulley so I can get to the bolts to take the pump off, and I rented one of these pulley removers from the parts store. Should the "button" on the end of the center screw fit INTO the hole In the center of the pulley, or should it just be pressed against the outside?
Posted from MustangForums.com App for Android
IronMan0002005 is offline
Old 03-02-2013, 01:35 PM
IronMan0002005
Ok, I got all of that worked out. But I got the new pump on the and the pulley reinstalled, fluid added and all that jazz. I turn the car on and the brand new pump sounds worse than the old one did. any suggests as to why other than the possibility that it's a bad pump?
Old 03-02-2013, 11:15 PM
belairbrian
belairbrian's Avatar
Initially they can be noisy. Have you slowly cycled the steering to bleed any air out of the system?
belairbrian is offline
Old 03-03-2013, 10:28 AM
IronMan0002005
That was the first thing I did. Turned the car on and turned the wheel to both extremes at least a dozen times hoping it would go away but it didn't. I also stove it for an hour to and from work but it was still there at the end of the day.
Old 03-03-2013, 10:33 PM
stauber32
stauber32's Avatar
I believe the actually power steering pump itself has a sticker on it that says something like 30 days or 500 miles and it should calm. I had the same problem with mine so i waited it out and it worked..... now its back to the wonderful ford ps noise. (i shouldnt have wasted 60 bucks just for the noise).
stauber32 is offline
Old 03-04-2013, 12:39 AM
IronMan0002005
In really going it goes away, it sounds horrible. I think it's actually worse than the original pump. But I changed mine partially because it was leaking, so I got at least half of my problem fixed.
Old 03-04-2013, 11:22 AM
IronMan0002005
Could the noise possibly be from something with the pulley? Either a defective pulley or improper installation?
Old 03-04-2013, 01:44 PM
BabyGT
BabyGT's Avatar
It could take up to a month I have heard for it to quite down as stated above.
BabyGT is offline
Old 03-06-2013, 05:43 AM
petrock
petrock's Avatar
After driving the car around a while, with it at normal operating temps, park the car and let the motor idle for a minute or two. Then pull the power steering fluid reservoir cap and look for air bubbles. If you see any air bubbles then you have a leak in the return (low pressure) side of the power steering system. Good luck...
petrock is offline
Old 03-06-2013, 01:21 PM
stauber32
stauber32's Avatar
About your pulley, its not that. I literally pried it off and snapped it so i had to buy a new pulley and put it on. It still was loud and gross!
did you bleed it entirely out? like the drain hoses?
Quick Reply: Power steering pump pulley removal
