Rear End Click
Old 08-06-2014, 01:35 PM
JMHamilton88
JMHamilton88's Avatar
Default Rear End Click
I have a 1999 Ford Mustang V6 5 speed manual.
When I shift I hear/feel a pretty pronounced click towards the rear end. What could this be? And how much should I expect to pay with parts/labor to fix it.
I'm hoping it is just a bearing replacement and not the entire rear end.
Any help is greatly appreciated!
thanks,
Jeff
JMHamilton88 is offline
Old 08-07-2014, 05:57 AM
dawson1112
dawson1112's Avatar
Its probably just a U-joint that is bad.
Drive line noise is sometimes hard to diagnose, because it can transmit through the drive shaft and sound like its coming from any where , especially when your sitting in the cabin.
It could also be a bad suspension component , such as a bad spring, or control arm bushing. When torque is applied to the rear end it wants to rotate upward, the upper control arms are there to absorb this force. If a bushing is bad it may make a noise as torque is applied.
I suggest you put the rear up on jack stands , and get under the car and look for any slop in the drive line. It helps to have a helper that can rotate the wheels while you listen for the noise from under the car. If its the U-joint it should be pretty apparent when you turn the drive shaft. Check the pinion flange for side to side or up and down lateral movement as well. Also check the tail housing bushing on the transmission for any movement by pushing the drive shaft up and down .
A suspension noise may be a little harder to diagnose, because you cant put the force on it that the engine can.
If you are not comfortable under a car and are not sure of how to go about diagnosing the issue then I suggest you take it to a reputable mechanic or someone who is a bit more confident in doing the job.
dawson1112 is offline
Old 08-10-2014, 07:45 PM
NicStaner
NicStaner's Avatar
+1 on Checking the U-Joint, most common part. If its not that or suspension there may be excessive backlash or worn teeth.
If you have to take it somewhere something to consider may be taking it to a driveline shop rather than a dealership/independent shop. Around my area we have a lot of trucking and there's a shop called driveline that works mostly on rigs, but they will take on cars and pickups. They're a lot cheaper here comparably due to better parts vendors and their labor being faster since they specialize in that specific area.
NicStaner is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
carid
07-08-2016 09:55 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Dragonus18
09-09-2015 01:21 AM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: Rear End Click
