Need Help: 2000 Mustang V6 Rough Start(cold) Rough Idle, Misfire/Shudder
#41
I'm going to keep my eye on it, but wouldn't doubt I'm having that problem. I had installed a new Autozone PCV valve and grommet a while back. I noticed the area on the VC where the original grommet/PCV was mounted was a little gunked up. I cleaned it off and installed the new grommet/PCV. That area had stayed spotless, however I had pulled the plugs not long after that and they all had a little oil residue on the threads. I swapped back the original PCV valve, in the new grommet. I pulled the plugs last weekend and they were all clean, except the #3 & 6 which had a little bit of oil residue on the threads. The #6 being the worst. Also, I noticed it's a little wet around that PCV grommet. So, these could be a combination of A) the ****ty design of PCV ventilation and B) the AZ valve isn't calibrated correctly to deal with the excessive oil suction of the PCV system. I may order a Motorcraft valve and possibly do the in-line filter mod to help reduce. I've heard mixed feelings about the 01+ valve covers helping little if at all with the issue.
#42
But back to the engine shudder problem, after the box of parts I've thrown at this thing, I'm going to have to do a vacuum test and/or compression test to see what it pulls. Someone else had mentioned the rough cold start symptoms may be related to blockage somewhere in the EGR system, which I suppose if bad enough could lead to this engine shudder problem.
treesloth
09-28-2015 07:03 AM
