Mach 460 sound system and no bass
Old 11-14-2014, 04:20 PM
BabyGT
BabyGT's Avatar
Originally Posted by Daehawk
How could it have 8 speakers when there are only 6 places for them?
2 in bottom of door
2 in door sails
2 in rear deck
Unless there are spots in the top front dash...if so mine are missing lol.
Link 1
LINK 2
LINK 3
The 460 uses strange amps and ohms.
First link, 6th pic down, first one of door open, at top of door on inside of where the mirror bolts to is the tweeter, that makes 2 speakers per door.
So for a hardtop that's 4 in doors, 2 in sails, and 2 on deck for a total of 8.
In a vert its same setup for doors but 2 on each side for sail section so 4 in door, and 4 beside back seat for a total of 8.
BabyGT is offline
Old 11-14-2014, 09:46 PM
Daehawk
Daehawk's Avatar
That one at the mirror is the sails. I asked Crutchfield if that was a tweeter and they said no and gave me speaker recommendations. All were for 6 speakers. 2 6x8 in the deck, 2 6x8 in the bottom door, and some kind of little tiny speaker for the sails at the mirror. But they swore it wasn't a tweeter...i also thought it was a tweeter. I mean even that webpage says tweeters. Shrug.
Daehawk is offline
Old 11-15-2014, 06:10 AM
BabyGT
BabyGT's Avatar
A sail panel would be the panel for the b pillar, the panel between the front and back seats on either side. I promise you whoever you talked to at Crutchfield was wrong.
BabyGT is offline
Old 11-15-2014, 09:22 AM
Daehawk
Daehawk's Avatar
hmmmm.
Daehawk is offline
Old 11-15-2014, 04:44 PM
PNYXPRESS
PNYXPRESS's Avatar
Are you sure there are speakers in the sail panels of the mach460 coupe? I cut up a Mach460 car and it has regular sail panels. Only speakers in the rear was the Mach setup under the rear dash.
PNYXPRESS is offline
Old 11-15-2014, 04:46 PM
Daehawk
Daehawk's Avatar
There are none in the back quarter panel area. I miss them there because my Trans-Ams had them there.
Daehawk is offline
Old 11-15-2014, 06:35 PM
gagemcc
gagemcc's Avatar
Sorry for the late reply guys but I have a few pictures, as you can see they cut the wires off the original connector and connected them to the new connector for the aftermarket radio. There is a second connector that I have no idea where it goes to and by the looks of it the radio wouldn't support it anyway. Then there is the orange cable which is for the antenna. There's an amp somewhere around the dash for the woofers in the doors right? Where would it be? Tonight I am taking apart the amps to see if they are blown.
gagemcc is offline
Old 11-15-2014, 06:36 PM
gagemcc
gagemcc's Avatar
And there wasn't anything connected to the RCA (Didn't see the edit function after posting this)
gagemcc is offline
Old 11-16-2014, 06:38 AM
BabyGT
BabyGT's Avatar
You are definitely missing the extra harness adapter. The third pic down, the grey plug with red face beside antenna is the amp harness plug, that's where the harness with the rca plugs attaches, your amps just aren't getting a signal to turn on. And you do have the standard harness adapter. That fat grey plug is the harness adapter. They have not cut the factory harness so you are in good shape.
BabyGT is offline
Old 11-16-2014, 09:15 PM
gagemcc
gagemcc's Avatar
Ohhh alright, I'll order the adapter right away because I have been driving the car for five months and have gotten a little tired of a sound system with zero bass. Thanks for the help man!
gagemcc is offline
Quick Reply: Mach 460 sound system and no bass
