1999 v6 mustang vibrating
I have a 1999 v6 3.8l mustang. 35th anniversary edition. The car vibrates annoyingly when at idle and while driving. Ive changed both motor mounts and transmission mount. The crank pulley is tight and not wobbling. Drive shaft is in good condition no clinking noises or dramatic wobbling when i checked it.i just cant figure out what is going on. Any suggestions as to what the issue may be?
How many miles are on the car, and has the ignition system been serviced (new plugs/wires)?
Check out everything first - ignition, fuel and engine mechanicals (compression). I had the same problem with a 2000 Mustang V6. I eliminated all possibilities I could think of and then replaced the Harmonic balancer. I know you said you checked it - I checked mine too. It looked fine, but somehow it had slipped on the rubber insert and threw the whole engine off balance. I changed the HB and the engine was smooth again. I say to check everything before replacing the HB, because it is a dealer part around $350.
Corky
Corky
Corky
Corky
Cannibal_carnies
03-02-2023 06:17 PM
