sway bar on 2004 v6
sway bar on 2004 v6
I saw this on the tech articles, https://mustangforums.com/forum/v6-1...r-install.html
So all mustangs made after 97 (?) got no rear sway bars? I'm not sure if mine has one last time I looked at the rear differential.
https://www.facebook.com/diyfordmustang
None of the 99-04 V6 came with one, you can run any rear sway off a fox, SN95, new edge GT, etc. They were different diameters depending on the year and trim. You just need to also get the installation hardware off said vehicles to swap into your '04...assuming that's what you have. There are 4 bolts and 4 special threaded clips which are affixed to the sway bar where the bolts run through. In case you go shopping for used sway bars.
really odd since I don't have one on my '04! what's the reasoning behind that? keep cost down or as if the v6 doesn't need rear sway bars at all?
just one of the reasons why even with the new tires up front I felt that the steering on the mustang is weird compared to my other cars (this is my first mustang)
is this the understeer they're talking about?
Diode Dynamics
45
04-13-2022 01:51 PM
NorthAmericanTuning
09-28-2016 09:32 AM
05 Mustang
Georgia Regional Chapter
02-17-2016 08:33 AM
