Wiring key-less entry
I have two remotes. Original one from Ford that unlocks and locks the car, and a Prestige remote control for my alarm.The guy who installed the alarm system for me said it would be $25 cheaper to have them separate.
I was wondering how I could do it myself where the alarm remote would also unlock/lock my car.
You will also need the installation instructions from your Prestige alarm system because not all remote entry boxes work like the next. There may be a jumper you need to install or remove to change the unlock signal from 12v to Ground, because some cars use a ground signal from the body control module while some use a 12v signal to trigger it. I haven't ever done one in a mustang so I cant say for sure how its set up.
your alarm should have wires for the door lock/unlock, you just simply tap them (on most remote alarm system) to the wires in your door boot. there's a note that since the door wires are connected to the GEM module you need to use diodes to isolate them.
http://diagrams.marktoonen.nl/DOWNLO...0ISOLATION.pdf
http://diagrams.marktoonen.nl/printl...&ModelID=14091
https://www.facebook.com/diyfordmustang
sonic245
04-20-2016 08:40 AM
Dan Moldovan
04-06-2016 09:40 AM
03-25-2016 12:47 PM
