Engine Shaking While Idling And Driving
Well, I found what is causing the misfire. I have low compression on every cylinder on the passengers side. I'm not sure what's causing it yet. I'm going to do a leak down test tomorrow and see where the problem is coming from. I guess while i'm at it i'll also do a compression check on all the cylinders on the drivers side just to be sure. I feel like I have a world full of problems that are just waiting to be discovered.
Thanks a lot for the help by the way. I've posted this same issue on three different forums and you're the only person to attempt to give some real help. I definitely appreciate it.
Anytime. Ill try. Never hurts to at least try to help someone.
Hope you dont need a full set of rings. Maybe its just a bad head gasket. Seems one problem is leading to another. At least you have a full new spark setup and wont have to fool with that for a few years.
Yeah I'm hoping it's as simple as a head gasket though I just replaced that about 200 miles ago when I replaced the lifters. But then again maybe that's why it could be the head gasket. Who knows? I'm actually looking into what it would take to do a complete engine swap at the moment. Just weighing my options at this point.
Just an update, it just hit me yesterday what my problem most likely is. For about a week or more before I started misfiring I was having a problem with my radiator spewing coolant out of the radiator cap. It was only a small amount (or so I thought) so I didn't rush to find a solution to the problem. For some reason, I never put two and two together to realize that that back pressure and my misfiring problem is a dead giveaway that I have a blown head gasket or a cracked head. My guess is that my head gasket slowly started failing which was allowing the compression from the cylinders to leak into the cooling jacket which caused the coolant to spew out of the radiator cap and eventually it failed almost completely which is why i'm now misfiring. I feel so disappointed in myself for throwing so much money at parts when the answer was right in front of me..
