3.73 gears and posi rearend
Old 01-19-2006, 03:46 AM
primergray
primergray's Avatar
Default 3.73 gears and posi rearend
I was pricing this today and had one shop tell me they could do the swap and install for X amount of dollars.
I called another shop for a quote and they told me that the posi is a waste of money and just go with the gear only because the 3.8 will never spin the tires.
This is a 2000 Mustang 3.8l Coupe. CAI, UDP and 2.25 Catback true dual with MagnaFlow exhaust.
This will have Drag Radials for the track.
Who is right?
Thanks in advance!
Jack
primergray is offline
Old 01-19-2006, 03:51 AM
jthorn9
The Godfather
jthorn9's Avatar
Default RE: 3.73 gears and posi rearend
The point is not to spend the tires, it's to prevent it, man that guy is a moron, get the gears and the t-lok because your stock differential spends the back right tire for speed and then transfers the rest of the hp to the left tire to give you traction, it's kinda hard to explain, but in other words, both tires don't evenly supply the power a t-lok fixes this by allowing both wheels to supply equal power while limiting the amount of spinning out you're going to do therefor giving you better off the line speed and accelleration.
jthorn9 is offline
Old 01-19-2006, 04:00 AM
jgt58
jgt58's Avatar
Dude , find a shop that knows what they are doing. Lisen i've had them all V8 mustangs , v6 mustangs and now a 2.3L mustang. Out of all of them the best to drive was the V6 , it has soooooo much potential. You will thanks yourself for getting gears and a posi. you might also wanna consider a chip from www.fordchip.com to recalibrate your speedo when you do the gear swap. Good luck!!!
jgt58 is offline
Old 01-19-2006, 08:44 AM
mustangman02232
mustangman02232's Avatar
open diffs like we have supply power to both rear tires until one looses traction, then 100% of the torque is transfered to that one tire, a t-lok will lock both of the tires together and they will spin at the same speed, dont get the ford chip to recalibrate ths speedo get a diablo, also, forget the 3.73s go with 4.10s
mustangman02232 is offline
Old 01-19-2006, 09:33 AM
nanaki
Retired MF Moderator
nanaki's Avatar
what a momo.
oh, and get 4.10s, not 3.73s.
nanaki is offline
Old 01-19-2006, 06:39 PM
jgt58
jgt58's Avatar
i know of the old saying DONT FEAR THE GEAR , but imo the 3.73's are perfect for a 5 speed and 4.10's are perfect for an automatic. But just imo
jgt58 is offline
Old 01-19-2006, 07:50 PM
TorchV6
TorchV6's Avatar
I think the same I think that the 4.10's are over kill for manual I want 3.73's someone is selling some cheap in the parts part of the forums I wish I had money [:@]
TorchV6 is offline
Old 01-19-2006, 08:45 PM
nanaki
nanaki's Avatar
and how many autos and manuals have you owned with both sets of gears to come to that conclusion?
nanaki is offline
Old 01-19-2006, 08:49 PM
jgt58
jgt58's Avatar
ive owned a 4.10 GT manual and it was just toooo much gear for a manual. Id usually have to start in 2nd gear if i wanted a smooth start. My v6 auto i had 4.10's in and I was thrilled with them. I have driven a 5 speed v6 with a 3.73 gear and it was smooth as silk not too much acceleration just enough for a good kick in the seat.
jgt58 is offline
Old 01-19-2006, 08:51 PM
nanaki
nanaki's Avatar
i've got 3.73s now and i'd definitely get 4.10s installed if i didn't have to pay another $500 for a gear swap.
nanaki is offline
Quick Reply: 3.73 gears and posi rearend
