Whenever i make a sharp right turn, my car shakes. It also shakes when i decelerate quickly, for example a highway off-ramp. The steering also seems to be a bit looser than it used to be, and at very high speeds the car drifts around a bit. Is this an alignment problem or something more serious? Thank you for all your help,
-Mike
Warped rotors won't really effect steering. they will produce a pulsation, but won't loosen the steering. Before going out and buying ANY parts, have a good shop check out the front end. Some give free front end inspections, as well as free brake inspections. Have both checked out. But my money is on a steering component..likely an inner tie rod end.
