Are these safe?
Old 05-06-2007, 11:23 AM
raz54
raz54's Avatar
Default RE: Are these safe?
ORIGINAL: TheMichiganRA
Gas is 3.30 here. It totally blows.
Damn you're lucky, it's $3.65 here for reg.
I have a theroy about the acetone. I think it has some thing to do with the oxygenation of the gas, maybe removing it?
raz54 is offline
Old 05-06-2007, 11:48 AM
cisurfer
cisurfer's Avatar
when i was on explorerfourms a whole bunch of ppl were doing the acetone thing and it work for them
cisurfer is offline
Old 05-06-2007, 11:50 AM
ZZmustang
Banned
ZZmustang's Avatar
There are several types of acetone, Industrial , is used in making large amounts of chemicals, and as a feed stock. Humans make it when they are starving.
As a fuel additive it would probably be ok, but , and that is a Big Butt, what it would do to the seals on the fuel injectors or the fuel pump or the fuel line that is not steel, is a guess. Maybe any car than can run E85 would be safe for acetone, but I wouldn't use it on older vehicles.
acetone, is an oxidizer, meaning it carries it's own oxygen, Like Nitro methane or Nitrous. The chemical formula C3H6O means it will burn very rapidly, the "O" will help.
If your going to try this, don't use to much, What you are really doing is increasing HP and by doing this use less gas peddle and less gas. Your engine still needs the right air/fuel ratio to run,
ZZmustang is offline
Old 05-06-2007, 11:53 AM
deezelnut
I ♥ Acer
deezelnut's Avatar
where i am it is around 1600 won, or $1.75, per liter. and the Koreans drive like maniacs. they don't have gas pedals, it's an On/Off switch.
deezelnut is offline
Old 05-06-2007, 12:22 PM
raz54
raz54's Avatar
ORIGINAL: deezelnut
LOL.
raz54 is offline
Old 05-06-2007, 12:25 PM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
Acetone is safe, in the right percentage. It doesn't hurt any of the seals or anything, I mean it's a nail polish remover, but gasoline will strip paint too. It's simply an atomization tool, which as we all know, increased atomization equals incresased performance. The fuel burns better, less is used, engine doesn't work as hard, therefore you end up with increased gas mileage.
The danger is only present when you put in too much. no more than 3oz per 10gal in your tank, but you're supposed to work your way up starting at 1oz per 10 gallons.
Ryan
RyansQuick6 is offline
Old 05-06-2007, 01:14 PM
ZZmustang
Banned
ZZmustang's Avatar
RyansQuick6
It doesn't hurt any of the seals or anything?????????// Wow , that’s a heck of a statement?
But then, You might put E85 in a carburetor engine? Each manufacturer put in different seals and the material that the seals are made of react differently with different chemicals. Put a rubber seal in some alcoholic and see. put some gas in a Styrofoam cup.
Old 05-06-2007, 02:12 PM
v6stang07
v6stang07's Avatar
well i dunno, the seals is what i am really worried about, i just had to replace a fuel pump and it wasnt fun so i would like to keep my fuel system runnin for a while but i would also like to try this out
v6stang07 is offline
Old 05-06-2007, 03:24 PM
FBCBEER
FBCBEER's Avatar
Yeah, it seems that if it worked so well, everyone would be using it. Im not sold on it yet. Maybe Ill try later.
FBCBEER is offline
Old 05-06-2007, 04:08 PM
Durr727
Durr727's Avatar
Hmm. Both cool finds, I might try it, but I want someone else to **** up their fuel system first.
Durr727 is offline
Quick Reply: Are these safe?
