Fuel System upgrade for Supercharged 4.0
Quick question,
I just put a powerdyne supercharger running about 7-8lbs of boost on my 2005 v6. I also added 24lb Ford Racing injectors. However, it just can't seem to get enough gas. When I step down, it lugs hard. But when I bring it up slowly, the power is all there.
Do I need a more robust fuel pump? Or is there some kind of adjustment I can do? Anyone know what my next step is?
Thanks,
Zak
Thanks,
Zak
Quick question,
Thanks,
Zak
Thanks,
Zak
Does Powerdyne make a kit for the 4.0? I know they make one for the GT
Hmmm buying the wrong injectors could certainly be the problem! I have tried a wide range of custom tunes using a diablo sport programmer. Have not dynoed the car. Powerdyne doesn't make a kit for the 4.0, it's a home-made rig.
I have the x-charger and that kit came with 39lbs injectors.
Well, like I said, it wasn't a kit. I just bought a powerdyne supercharger and made it work. I bought some injectors that were bigger, but not a lot bigger than stock. Looks like I made the wrong call, should have done more research. I just ordered some Ford Racing 39lb injectors.
You need 39 injectors. You are starving your engine for fuel. And without a proper tune, you are begging to destroy the engine!
Get some proper injectors and a proper tune before running it hard, please!
The fuel pump easily handles up to your moderate boost levels. I didn't start running into pump issues until doing over 10 psi, and then doing a wiring upgrade supported my 12+ psi with no problems. But, with 39# injectors and a proper tune.
Homebrew setup, inadequate injectors, no tune = BOOM
Get this fixed NOW while you still have an engine.
