2010 flush mount louvers
Old 03-25-2010, 11:05 PM
MOOK3456
MOOK3456's Avatar
Default 2010 flush mount louvers
Anyone have these? Thinking about em but not sure if I wanna remove the glass.... I'm either getting these linky or this "type" Linky ....Thoughts?
Also feel free to move this if its in wrong section Mod's...Wasn't even thinking.
MOOK3456 is offline
Old 03-26-2010, 02:24 PM
07 Stang
07 Stang's Avatar
I have the SHR louvers. If you are mechanically inclined and have a garage that's at least 60°, you can do it yourself. SHR does give instructions and there are some on here with pictures in the "HOW TO" section.
Since my car was in the shop for service, I let them install it.
I kept the glass and plan on using them as windows for an office once the extra garage is built.
07 Stang is offline
Old 03-26-2010, 03:36 PM
MOOK3456
MOOK3456's Avatar
Cool, are they "solid" as in....I guess what I'm asking is do you feel it would be easy for them to be popped out with a screwdriver (3m tape)? Or are the bolted/screwed somehow?
MOOK3456 is offline
Old 03-26-2010, 05:51 PM
StripeyGT
StripeyGT's Avatar
Thumbs up
Don't have 'em, but I like these:
StripeyGT is offline
Old 03-26-2010, 11:04 PM
So_Cali
So_Cali's Avatar
I think once theyre in, theyre staying there. I believe you silicone them in...Not too sure but, I'm sure you can't just pry them out. I'd get those if I had to do it again....Just sayin
So_Cali is offline
Old 03-28-2010, 07:05 AM
07 Stang
07 Stang's Avatar
Yes, they are definitely solid. They are installed exactly the same as if it were glass. In order to take the louvers out, you have to use the same procedure as removing the glass.
Many installers use 3M One-Step Adhesion Promoter then they use 3M Urethane Window Sealer / Adhesive.
Tool kit for window removal;
http://www.silverhorseracing.com/car...ategory_id=267
3m Adhesion Promoter;
http://www.silverhorseracing.com/car...ategory_id=266
3m Adhesive/Sealer;
07 Stang is offline
Old 03-28-2010, 08:33 AM
MOOK3456
MOOK3456's Avatar
Good stuff man ty.
MOOK3456 is offline
Old 03-28-2010, 03:42 PM
BigGameHunter589
BigGameHunter589's Avatar
are the 2010 side glass panels the same size as the 05? they probly aren't but knowing ford i wouldnt be surprised
BigGameHunter589 is offline
Old 03-28-2010, 07:19 PM
07 Stang
07 Stang's Avatar
I believe it's exactly the same.
07 Stang is offline
Old 03-31-2010, 05:25 PM
Xcelsius
Xcelsius's Avatar
I thought the rear quarter windows were the same too. I wonder why SHR has ten dollars added to "10+" sets...
Xcelsius is offline
Quick Reply: 2010 flush mount louvers
