Car chugging
Old 01-12-2012, 07:11 AM
maxshuty
maxshuty's Avatar
Default Car chugging
I started my car this morning and it died right after I started it and then it started the second time it started right up. It was shaking though. I let it warm up and it went away. I've driven the car the last threes Minnesota winters and it's never done this to me. Do I need a new battery or what's the deal?
maxshuty is offline
Old 01-12-2012, 10:34 AM
up_yours_7
up_yours_7's Avatar
Could also be the fuel your putting in. Go buy some of that fuel and injector cleaner see if that helps
up_yours_7 is offline
Old 01-12-2012, 06:07 PM
maxshuty
maxshuty's Avatar
I've always used 93 grade
maxshuty is offline
Old 01-12-2012, 07:32 PM
Nuke
Nuke's Avatar
It sounds like a fuel issue but I suspect it was just a slug of moisture. If it happens again, try some HEET (or however it's spelled) or a similar product and be sure to refill with fuel from a quality source. May have been a bit of dirt. Being that it was momentary, whatever it was has passed.
Nuke is offline
Old 01-12-2012, 08:21 PM
maxshuty
maxshuty's Avatar
Will heet mes up with my tune or anything? The x charger is going on tomorrow so I need to get this resolved. Ill see of it does it again tonight. Could it just have been from the cold weather? It's just weird if it's the cold because it's never done it previous years
maxshuty is offline
Old 01-12-2012, 08:44 PM
Moderator
JimC's Avatar
How long since you changed the fuel filter?
It might be a good idea to change it anyway with the Xcharger installation if you have many miles on it. I change mine out every spring and usually in the fall (I missed it this year I just realized), but I put over 30,000 miles a year on the car and it sees a lot of weekend race duty as well from April through November.
JimC is offline
Old 01-12-2012, 09:00 PM
maxshuty
maxshuty's Avatar
I last changed the filter in the summer. I'll change it again soon - I don't think it sod be that as I haven't put more than 10k miles on it I dont think. Seeing a it's a cheap part and pretty easy go change I'll change it when I do my rear brakes probably in two weeks
maxshuty is offline
Old 01-12-2012, 09:55 PM
Moderator
JimC's Avatar
Could be just one of those gremlins that goes as quick as it came. I've had that chug happen on my car before in the cold. Could be some moisture - how did the car run later in the day - was it parked outside?
Since you are putting the Xcharger on I wouldn't add HEET - it could change your octane rating (I haven't looked at the label to see what is in it so that may not be an issue so I'm not sure what they use to dry out the moisture). You do have the car filled with premium to get ready for the Xcharger installation right? With the Xcharger install you will be putting new fuel injectors in so if you had a slightly dirty injector that won't be there after the install.
JimC is offline
Old 01-12-2012, 09:57 PM
BWfVA
BWfVA's Avatar
I would guess that it very possible that there was some water in the gas. I would try a different station. Also some new plugs when you install the xcharger
BWfVA is offline
Old 01-12-2012, 10:15 PM
maxshuty
maxshuty's Avatar
Come to think of it - last time I filled up right before I did that I waded my car. Perhaps the heat change from the temp of the gas created some condensation in the tank. Hopefully it's gone I'll did out in ten minutes when I head to work.
@jimc yes, I previously had been running a 93 race tune do for the past year or two I've always used 93
maxshuty is offline
Quick Reply: Car chugging
