rear sway bar
Old 03-10-2013, 05:06 PM
05screaminyellow
05screaminyellow's Avatar
Default rear sway bar
just picked up this sway bar/anti roll bar for my 05 does this look like the right bar for the vert ? I dont have my car home yet its still in storage till apr3 so I cant go under and see .. I was told the vert and coupe have different bars hope this is the right one
also picked up these for the rear, good by to the factory rake... I cant wait to get it home especially when today hit 62 degrees
05screaminyellow is offline
Old 03-10-2013, 06:59 PM
Doogie65
Doogie65's Avatar
Sway bar looks correct as it has the extra bends across the middle to clear the frame braces. I also just compared it to some pics of a Saleen rear bar I just sold and it looks the same.
Doogie65 is offline
Old 03-10-2013, 07:17 PM
Moderator
JimC's Avatar
Plus it has the white links. The coupe links are dark color.
JimC is offline
Old 03-10-2013, 08:16 PM
akdoggie
akdoggie's Avatar
Definitely a Mustang setup. I saw the factory tag on the bar, but was surprised to see the white links. They don't look like they have the special bushings, but looks sort of cool the way its set up. Good luck with the install.
akdoggie is offline
Old 03-11-2013, 09:19 AM
157dB
Cut & Paste Expert
157dB's Avatar
White end links says its for the vert...
Seen a lot of sway bars under 05-09 S197s
and thats a vert bar indeed...
157dB is offline
Old 03-12-2013, 01:23 AM
05screaminyellow
perfect .. glad its the right one, thanks for the quick response guys
now i just need the next 3 weeks to go by fast so i can bring it home and get the springs and sway bar installed and drive it .
Old 03-12-2013, 07:32 AM
Topless Stang
Topless Stang's Avatar
Did you put new bushings in? I picked up one too, but I think I'm going to replace the bushings before I install it. I just hope that its not too hard of a process....
Topless Stang is offline
Old 03-12-2013, 10:38 AM
05screaminyellow
no i just got it the other day i wont be changing the bushings in it, the sway bar is new and came with the bushings
Old 03-12-2013, 12:30 PM
The01Cav
The01Cav's Avatar
My 09 Pony Coupe has White links...
The01Cav is offline
Old 03-13-2013, 07:42 AM
Topless Stang
Mine is new too, along with the front GT sway I picked up, but i still wanted to upgrade the bushings to poly bushings from Energy Suspension. It's a cheap upgrade and will last much longer and give more support that the OEM rubber....at least that's what I've read. I picked up the front set for $25 and the rears for $35. I looks like it will be a PITA to get the old ones out and put the new ones in, so i was looking to see if you had done it. Good luck with your install!
Quick Reply: rear sway bar
