Going to dyno my V6 this weekend... Which gear is 1:1 with the 3.31's?
08-15-2013, 12:53 PM
like the very long title says... lol
i read that the mt82 is 1:1 in fifth but.... i would hit the speed limiter in fifth...
08-15-2013, 01:05 PM
08-15-2013, 01:10 PM
thanks Pete, so dyno in 4th?
also did Ford fix the exploding drive shaft issues?
08-15-2013, 01:13 PM
Dyno in 4th, the drive shaft is still an issue. Forgot to add in my sig that I have a Dynotech aluminum 1 piece.
08-15-2013, 01:16 PM
god... you figure Ford would fix such a silly issue...
08-15-2013, 01:18 PM
Yep. If you research it, it seems to be a fairly rare occurrence. I swapped mine just because I knew I was going to take the limiter off and run it fast.
08-15-2013, 04:21 PM
ya, ill be swapping mine down the road.
08-17-2013, 03:40 PM
Am Real interested in how your car does on the Dyno !!
I'll guess 241 hp
08-17-2013, 04:35 PM
Depending on temps, humidity and all that good stuff he should be in the 250's with a MT82 bone stock. Unless its a mustang dyno.
08-19-2013, 12:25 PM
i dyno'd at 258 whp/232 wtq
