SN95 8.8 Rear Axle
Old 01-15-2014, 05:31 PM
DeadBob
DeadBob's Avatar
Default SN95 8.8 Rear Axle
Would an 8.8 rear axle off of an SN95 fit up to a S197, I understand with a newer one all you'd need to get it to match up is a the flange, but seeing as it's a different model, would it fit, and would it be worth it?
DeadBob is offline
Old 01-15-2014, 07:46 PM
2007StangV6
2007StangV6's Avatar
Not 100% sure, but I would imagine that the SN95 axles are shorter width wise compared to the newer axles. Not to mention the points where everything bolts up might be different.
If you buy a '05-'10 8.8, you'll need to buy a cobra flange. If you were get one from a '11+, it will bolt right up, no flange needed.
2007StangV6 is offline
Old 01-15-2014, 09:54 PM
Moderator
JimC's Avatar
SN95 is a 4 link connection - the S197 uses a 3 link so in addition to width, the mounting points are all different.
JimC is offline
Old 01-15-2014, 10:42 PM
tx_zstang
tx_zstang's Avatar
Wont fit. Different bolt-on points. Must use a '05 or newer rear end.
tx_zstang is offline
Old 01-16-2014, 11:20 AM
157dB
Cut & Paste Expert
157dB's Avatar
different mounting points for a SN95 and a S197
+1
04 Cobra flange would be needed if the SN95
rear end would bolt up... but it wont so the flange
is a moot point...
157dB is offline
11-10-2015 11:39 AM
67LimeCoupe
09-30-2015 04:46 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: SN95 8.8 Rear Axle
