Rattle Sound
Old 07-28-2014, 06:16 PM
Eismann
Eismann's Avatar
Default Rattle Sound
Recently I have had a rattle coming from what sounds like the exhaust on my 2005. I haven't been underneath to check since it can be difficult without proper stands or a lift. Sometimes it will only be at idle that it rattles. Other times it will be when I accelerate. I was feeling the mounts and they feel like the bushing are most of the way gone. Think that is all it might be?
Thanks in advance.
Eismann is offline
Old 07-28-2014, 07:05 PM
Nuke
Nuke's Avatar
A rattle could be anything. If it's at a specific RPM it could be exhaust or a number of other things that are activated at that particular harmonic. Get a set of Rhino ramps and start getting your hands dirty.
Nuke is offline
Old 07-28-2014, 07:14 PM
Eismann
Eismann's Avatar
The rattle isn't at any specific rpm. And it has a hollow sound. Goes right along with the vibration of the exhaust.
Eismann is offline
Old 07-28-2014, 10:22 PM
pkugrsq
pkugrsq's Avatar
Like above, it really could be anything. My Mustang rattled in several different places. Before I got the exhaust hangars adjusted, it'd rattle up against the suspension and the exhaust tip cutouts. Even after, the sheer vibration rattles the license plate (as I only have the top two screws) and one of the tips has come loose, which rattles too. It could really be annnnnnything.
pkugrsq is offline
Old 07-30-2014, 12:45 AM
tx_zstang
tx_zstang's Avatar
The '05's had a TSB for fixing rattles. The hangers on the transmission crossmembers tend to rattle over time. A fix (the tsb) is to use a worm clamp around each of those hangers to tighten them up.
I had such a nasty rattle develop on mine after about 20k miles, sounded like it was under the shifter. And this tbs fixed it.
But yeah, rattles can be from anywhere underneath.
tx_zstang is offline
Old 07-31-2014, 10:01 AM
kevinmalec
kevinmalec's Avatar
I also have a rattle sound under the car. It sounds like a tin can rattling around. I can hear it the loudest when accelerating in 1st gear.
I tightened my exhaust numerous times and it's still there. Some people said it maybe the exhaust heat shield.
kevinmalec is offline
Old 08-11-2014, 12:58 PM
unitedwestang
unitedwestang's Avatar
When converting to dual exhaust I bought aftermarket hangers for the driver's side. Over time the rubber in both of those hangers has worn and the hanger rod basically sat on the bottom of the metal "square" part of the hanger. HORRIBLE rattle. Ended up making my own hanger brackets and used the isolators from AutoZone--what I should have done from the beginning because the rubber in those aftermarket hangers was pure junk. The OEM hangers are still holding up fabulously.
Not saying that is your issue, but it may be worth looking into. You'd be surprised at how much your exhaust moves around when it hits resonance. If there's less than 1/4" of clearance between any part of your exhaust/hangers and any other part I'd seriously look at it.
unitedwestang is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Rattle Sound
