radio help!!!!¡!!
Old 08-15-2014, 06:15 PM
2010v6vert
2010v6vert's Avatar
Default radio help!!!!¡!!
Ok, I have a 2010 v6 and I went out to my car, started the car and the radio says mustang and doesn't work at all. I checked the fuse and it was fine. I have no idea what the problem is. Does anyone know what this could be and what I can do to fix it.
Thanks
2010v6vert is offline
Old 08-15-2014, 09:18 PM
Nuke
Nuke's Avatar
I'm stumped. Did you google it?
Nuke is offline
Old 08-15-2014, 10:43 PM
2010v6vert
2010v6vert's Avatar
I dont know what it is but I googled and and had mixed results. I went out to my car started it up and it was fine and working like nothing is wrong.
Old 08-15-2014, 10:56 PM
AJ06GT
AJ06GT's Avatar
Maybe the fuse pull reset it and fixed the issue unless you had already checked again after pulling the fuse. Either way, glad it's working again. I've got a junk Shaker 500 myself that's half dead. Really need to get back to my project of replacing it.
AJ06GT is offline
Old 08-15-2014, 10:59 PM
2010v6vert
2010v6vert's Avatar
I had pulled the fuse checked it and it was still screwing up. Went ran some errands with no radio and it sucked lol. Went back to the car and worked fine. I have no idea
Old 08-18-2014, 08:40 AM
FordService
Official Ford Rep
FordService's Avatar
Thanks
Hi 2010v6vert,
I recommend you have your dealer check it out and speak to your service manager. He is in the best position to ensure a proper diagnosis, and will be able to provide available options and/or coverage for any work needed. Also, remember most repairs done at a Ford Dealer come with a 24 months/unlimited miles warranty.
You can schedule an appointment online here.
Deysha
FordService is offline
Old 08-18-2014, 02:48 PM
2010v6vert
2010v6vert's Avatar
Originally Posted by FordService
Hi 2010v6vert,
Deysha
if it does it again i will be more than happy too thank you
Old 08-19-2014, 06:51 AM
FordService
Official Ford Rep
No problem, 2010v6vert!
Deysha
Old 08-23-2014, 11:11 AM
157dB
Cut & Paste Expert
157dB's Avatar
Before getting bent over at the stalership, check your ACCESSORY DELAY RELAY.
Schedule an appointment at the bank for a loan to pay the service department
when they are done with your stang...
157dB is offline
Old 08-23-2014, 11:13 AM
2010v6vert
2010v6vert's Avatar
That's the truth.... I need a new abs module and it anywhere from 1400 to 2200. Depending on if its the electronics or not. Its going to wait lol.....
Quick Reply: radio help!!!!¡!!
