Wrong speed in odometer!!!
Old 09-10-2014, 01:05 PM
firazza
firazza's Avatar
Default Wrong speed in odometer!!!
My 2013 mustang V6 automatic is reading a wrong speed in odometer.. I've just upgraded the rear axle from factory to 3.73 (ford racing) and I don't know what is going on and/or how to solve it
does anybody know what to do? there are no dealers nearby me, that's why im askinge dash
Thanks!
firazza is offline
Old 09-10-2014, 01:10 PM
2011V6Nicole
2011V6Nicole's Avatar
you need to have the ecu flashed or if you have a hand held tuner you can adjust the settings yourself
2011V6Nicole is offline
Old 09-11-2014, 10:52 PM
MustangInTexas
MustangInTexas's Avatar
If you're reading the speed off the odometer, it'll never be right. Besides that, what Nicole said.
MustangInTexas is offline
Old 09-12-2014, 12:02 AM
cruisin5268d
cruisin5268d's Avatar
I just spit my water out on my keyboard. Thanks for that.
OP, you changed the gearing of your powertrain system. Of course the speedometer will be off. You need to get the ECU flashed as has been said.
cruisin5268d is offline
Old 09-13-2014, 02:02 PM
Nuke
Nuke's Avatar
With the handheld, you can select which gears you have to adjust the PCM. You may as well order a custom tune with a the handheld tuner and pick up some significant RWHP. And if you ever change tires/wheels, you can adjust the tire revs/mile with the handheld,too.
Nuke is offline
Old 09-20-2014, 11:33 AM
firazza
firazza's Avatar
Thanks everybody for the answers
Which is the best equipment I could buy? Bama is good option?
firazza is offline
Old 09-21-2014, 01:51 PM
2005Redfire6
2005Redfire6's Avatar
Yeah, that will work.
2005Redfire6 is offline
Old 09-21-2014, 05:06 PM
Siber Express
Siber Express's Avatar
His Portuguese to English Dictionary might have misled him, it appears he is in Sao Paulo Brazil.
Siber Express is offline
Old 09-21-2014, 06:00 PM
oldfella
oldfella's Avatar
I have a 3.73 gear now in my 92, and have not installed the speedo gear kit. My mph are only off by 3mph, according to my GPS. I'm running 62 when the speedo says 65, if my gps is right.
oldfella is offline
Old 09-22-2014, 05:28 AM
firazza
firazza's Avatar
^^ The speed at my odometer is too much different, when I am at 130 kmh / 80 mph (by the GPS) the odometer shows that I am at 180kmh / 110 mph, and the car cannot go faster than this.
firazza is offline
Quick Reply: Wrong speed in odometer!!!
