2007 v6
Old 01-31-2016, 08:04 PM
carter2007v6
carter2007v6's Avatar
Default 2007 v6
i have a 2007 v6 with a k&n cold air intake and a flow master exhaust. i wanna do something to add some more power for cheap. what should i do?
carter2007v6 is offline
Old 02-01-2016, 06:30 PM
Drophead08
Drophead08's Avatar
Good question; I'd be interested in the answers also.
Drophead08 is offline
Old 02-01-2016, 08:00 PM
NikolaShiznak4813@gmail.com
NikolaShiznak4813@gmail.com's Avatar
Intake and Exhaust is a good place to start, I'd go with some headers next if I were you but that's really the last cheap option. If you haven't invested in a good rim/tire setup that would be a good upgrade, granted not cheap. And for the 4.0 Forced Induction is really the only way to go to be really fast. Race cars ain't cheap! Cheap parts never lead to anything good!
NikolaShiznak4813@gmail.com is offline
Old 02-02-2016, 07:47 AM
Drophead08
Drophead08's Avatar
That's great advice, Nikola. I think Carter has picked all the low-hanging fruit with what he has already done.
I installed sequential turn signals yesterday but the car does not feel any faster. :-)
Old 02-02-2016, 10:12 AM
movielover40
movielover40's Avatar
A 3:73 rear end would give you some faster pickup.
movielover40 is offline
Old 02-02-2016, 05:32 PM
Buckshot Barry
Buckshot Barry's Avatar
Have you already added a custom tune?
Buckshot Barry is offline
Old 02-03-2016, 10:18 AM
09GT/CS
09GT/CS's Avatar
If you are considering boost check out mod box they used to make kits for the rangers when I was active on those forums and you can buy in pieces and build power as you go so its not hard on the wallet all at once. Never used their mustang kits but the ranger/bseries kits were pretty good for the price they have a breakdown chart of horsepower on their site based on pulley size/other upgrades. May be worth taking a look at. It uses the older M90's but they are plentiful and cheap now they claim 209-262RWHP depending on what add ons you get. You could also look at underdrive pulleys or heads/cams. Also I had pretty good luck with Tom Morana Racing with my 3.0l ranger he makes some good stuff for the 4.0's as well. He specializes in the V6's.
09GT/CS is offline
Old 02-09-2016, 09:25 PM
jimkaray
jimkaray's Avatar
Any engine mods (except u/d pulley) will not make any noticeable difference without a being tuned for the changes. So for any performance bump a custom tune is going to be necessary. It will change your car's personality from grocery getter to a true sporty ride. A Tuner with a custom tune is the least expensive mod that will actually make a worth while performance improvement. You can try to find a used, unlocked tuner and buy a tune from one of the reputable tuners you see talked about on the forums. I'm partial to VMP but I see their kit price has gone up as the tuner and parts get more expensive. They're in Central Florida so maybe near you too?
Not so cheap, especially if you have to pay for the labor, would be an aluminum drive shaft or a rear gear swap. Changing gears will need a tuner to correct the speedometer.
jimkaray is offline
Old 02-09-2016, 09:54 PM
Moderator
JimC's Avatar
Originally Posted by 09GT/CS
If you are considering boost... You could also look at underdrive pulleys or heads/cams.
If you were to go with a positive displacement blower (like Xcharger or the mod box), or even a centri for that matter, you would NOT want underdrive pulleys. The blower is belt driven so if you slow down the belt with underdrive pulleys, you won't get the full positive displacement power.
JimC is offline
Old 02-10-2016, 06:52 AM
JJHoover
JJHoover's Avatar
it would help if you tell us what your budget is
JJHoover is offline
derrill51
08-26-2008 04:45 PM
ShookMeAllNight
04-05-2008 12:46 AM
Justin00Stang
11-28-2007 03:52 PM
04stangman
05-04-2007 11:02 AM
NICO
12-09-2006 04:56 PM
Quick Reply: 2007 v6
