Sumitomo tires
Sumitomo tires
Alright i just wanted to know y'alls opinion on sumitomo tires. Im looking for something that i can spend less than 500 for all four of the tires that can fit 17" by 9" and 10.5" wheels
Alright soldier I'm not sure i want to do that... What the biggest wheels and tires I can get for a newedge without any mods? I wana stick with 17" but adjust the widths I guess...
Edit: I looked on am for the 17"x10.5" and almost all the reviews said that they do fit with a 315/35 on a newedge. The only problem is a simple brake line that needs to be moved
If you look at the picture below you can see that my car is lowered some what. I'm running 18's tho with a 285 tire and a one inch spacer. Once I return from Korea I'll be ditiching the spacer and going with some Mickey Thompson Street Raidials which will be 305/35/18. Those things are like 300 + a pop so I cannot afford to get my tires cut up by the fenders lip. Since you're going with 17's you should be able to go to a 305 tire with no problem. Is your car lowered any?
