Wheel bearing help
Old 10-31-2016, 01:04 AM
Hanc0ckp
Hanc0ckp's Avatar
Default Wheel bearing help
Hey yall i was wondering what is this? And how can i remove it. Im trying to change the rear wheel bearing on my 2002 mustang gt. Ive looked for the axle nut but to no avail.
Hanc0ckp is offline
Old 10-31-2016, 08:24 AM
Stoenr
Stoenr's Avatar
Pretty sure you have to take the rear diff cover off, remove the c clip to pull the axle.
Stoenr is offline
Old 10-31-2016, 09:47 AM
Hanc0ckp
Hanc0ckp's Avatar
And then change the bearing directly from the axle rod?
Hanc0ckp is offline
Old 10-31-2016, 09:49 AM
Stoenr
Stoenr's Avatar
  • jack up the car and put it on stands
  • remove the wheels
  • remove the brake calipers (don't disconnect hydraulics) and caliper brackets
  • remove the differential cover and drain the fluid
  • remove the spider pin retaining bolt and remove the pin
  • push the axles in enough to disengage the 'C' clip and remove the clip from the axles
  • pull the axles from the housing
  • use a slide hammer and yank the old bearings and seals from the housing
  • inspect the housing and bearing surfaces on the axles and replace anything unservicable
  • use a suitable bearing installer drive the new bearing into the housing
  • carefully install a new axle seal and lube the lip with a bit of diff oil
  • slide the axles back in place, re-install the C-clips and the spider pin and retaining bolt
  • re-assemble everything else...
Fill the diff with 75W140 synthetic hypoid oil and if necessary a bottle of friction modifier.
Stoenr is offline
Old 10-31-2016, 09:51 AM
Hanc0ckp
Hanc0ckp's Avatar
Thanks
Hanc0ckp is offline
Old 10-31-2016, 01:10 PM
Urambo Tauro
Urambo Tauro's Avatar
IIRC, you may also have to unbolt the ABS wheel speed sensor and remove it from the bracket in order for the axle-shaft to move inward enough to access the C-clip.
On my '95, the sensors were seized in there so bad that I destroyed them in the process, and had to replace them.
Urambo Tauro is offline
