Roush Wing Help
Old Feb 29, 2008 | 04:08 PM
kaponelb's Avatar
kaponelb
Default Roush Wing Help
I got my roush wing from the body shop and i removed the old spoiler i had on it the stock gt one but the holes are wrong when i try to align my new roush wing i dont have the roush template because i got the wing from someone what can i do and how do i fill the other holes up
Old Feb 29, 2008 | 04:35 PM
Fallout's Avatar
Fallout
Default RE: Roush Wing Help
umm i have the roush spoiler and while i didnt do the install(i let the shop do it when they painted it) i was 99.9% sure it used the 4 factory holes plus some new ones, dont understand why you say it wont line up. also call roush to try and get a template from them
Old Feb 29, 2008 | 04:56 PM
06roushv6's Avatar
06roushv6
hmmmm... .....the roush should line up with the factory holes (but you have to drill a new hole on both ends) i had no issues with the install. was the gt spoiler installed at the factory?
Old Feb 29, 2008 | 08:30 PM
kaponelb's Avatar
kaponelb
figured out the problem when i took it to the body shop to put a stock wing on it they didnt make the holes in the right place redid them and the wing fit like a charm
Old Feb 29, 2008 | 08:44 PM
chavalo_nm1's Avatar
chavalo_nm1
Old Mar 1, 2008 | 04:36 AM
06roushv6's Avatar
06roushv6
ORIGINAL: kaponelb
that makes sense noe, good to hear the problem has been corrected!
Old Mar 1, 2008 | 12:32 PM
kaponelb's Avatar
kaponelb
yeah it sucked cause i had to make knew holes but i put bondo on the other ones sanded it smooth and painted them so it looks good again but yeah problem figured out
Old Mar 1, 2008 | 01:26 PM
chavalo_nm1
Old Mar 2, 2008 | 04:27 AM
06roushv6's Avatar
06roushv6
are you happy with the new wing? i had the same problem with the holes, i had my gt spoiler attached after i got the car, and then i decided to do the roush myself, and the holes were about 3/8's of an inch too far back, so i had to re-drill some hoels it's scary drilling holes in your car, but i couldn't be happier with the results!
Old Mar 2, 2008 | 09:51 AM
kaponelb's Avatar
kaponelb
yes I love the. New roush spoiler was worth same here my holes were to back how did u fill in urs did you make holes for the side pieces I just used 3m tape
