Headlight/Taillight Upgrades
Old Sep 25, 2008 | 02:47 PM
The_Shirt's Avatar
The_Shirt
Default Headlight/Taillight Upgrades
Hello all,
The next things I want to do is likely install black housing LED taillights and black housing angel-eye headlights/foglights. I don't think the taillights will be too bad, but I read on a site feedback somewhere that you had to take the fenders off and remove the grill to get the headlights in and fastened properly. Does anyone have any experiece with these upgrades? I am pretty much a novice (i.e. non-mechanic) and don't want to be disassembling my car. I do think I am capable of relatively simple plug and play type upgrades, as in I don't mind unplugging and replugging in wiring.
Also, on the headlights, when I put the bulbs in (I would likely upgrade to better than stock bulbs), will they be adjusted by inserting them or will I need to find a shop somewhere to properly adjust them? I don't want to be blinding any oncoming drivers....thanks in advance for any assistance...bill
Old Sep 25, 2008 | 03:19 PM
suoperdave84's Avatar
suoperdave84
Both the front and rear assemblies require some disassembly. The front lights (if you intend to replace the entire housing) require removal of the front bumper, but not the fenders. It is not as difficult as you think though. There are 2 bolts where the bumper meets the fender on both sides (they are a bit of a pain) but the rest are right there in the open under the hood once you pop off the radiator cover. If you just want to replace bulbs, they simply twist into the assembly and plug in to the harness.
The rear assemblies don't require bumper removal, but several interior trunk pieces have to be removed. I think there are three bolts inside the trunk that hold each assembly in place. Once you loosen them, the assembly will slide outl.
Old Sep 25, 2008 | 05:09 PM
The_Shirt's Avatar
The_Shirt
Okay thanks. I'll have to put that off then or find a shop that will do it for me reasonably. I don't have a garage and really no safe place to do that much stuff. Well, I can probably do the rear, but no desire to crawl under and find fender bolts for the headlights. I really wish the sites that sell this stuff would quit saying "easy installation, less than 30 min" cause I'm thinking bumper removal is going to take more than 30 minutes...but thanks again for the feedback!
PaulH2
20
Jan 31, 2016 09:48 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
UrS4
Sep 30, 2015 10:13 AM
