Hid Lights
Old Dec 15, 2009 | 10:13 PM
rford426's Avatar
rford426
Originally Posted by DRock
I have HIDGUY.net and i have had NO PROBLEMS and it is all plug and play also backed up by a lifetime warranty and they are cheaper..........
x2 on HIDGUY.NET I also have two of his kits and have not had a single problem and doesn't put a dent in your wallet for less $$!!!!
Originally Posted by Retrosolutions
And without any bulb capping you are blinding everyone in front of you... there is really no two ways about it when the lamps do not have any bulb covers in them.
I have not once been flashed or anything from my hids not having "coatings". And I too have heard of your coating "peeling off"!! How do you determine if it was "scratched" off?
Old Dec 15, 2009 | 11:54 PM
Empire05's Avatar
Empire05
How can it get scratched off?
Old Dec 16, 2009 | 08:29 AM
Retrosolutions's Avatar
Retrosolutions
Former Sponsor
You have an 05, capping only applies to some 06 and all 07+ halogen lamps.
Your lamps have bulb caps built into them and require a bulb type that is already coated/masked.
So, it doesn't apply to you as you have the factory HID lamps, not the halogen lamps.
In the halogen lamps, 06+ without bulb covers capping is a requirement plain an simple, and we are the only manufacture offering such an option to those needing it.
By rubbing on the receptacle going in or coming out of the housings. However, the coating has been replaced with a capping service now, so that it can not be scratched off, costs less, and takes less time to add to an order.
Old Dec 16, 2009 | 02:03 PM
whtnblk.GT's Avatar
whtnblk.GT
Wanted to say I purchased my kit from Retro and Love them!!! i recommend them to everybody now!!!
About to purchase another kit for my fogs now!!!
Post pictures and Kelvin rating!
Old Dec 16, 2009 | 04:47 PM
Mayberry40's Avatar
Mayberry40
How many watts is in an 08 Mustang GT/CS ?
Old Dec 16, 2009 | 07:54 PM
Empire05's Avatar
Empire05
Will put pictures up first thing in the morning!!!
Quick question now guys,
ok so my headlights are 6000k with a 35w ballast.
For my foglights, should i do the same 6000k but with a 55w ballast to make it just a tad bit brighter? what do you guys think?
thanks!!
Old Dec 16, 2009 | 09:46 PM
flash_xx's Avatar
flash_xx
thanks!!
I went with 55W all around with 4300k bulbs, from retrosolutions of course.
The problem with the fogs is that the reflector sucks, that's why I got rid of mine and replaced them with a PIAA kit and put the HID in those .
Getting the bulbs in those fogs was a nightmare though, good thing I didn't break anything.
Old Dec 16, 2009 | 09:53 PM
rford426's Avatar
rford426
My fogs don't have any covers and drive with those on 24/7
Old Dec 17, 2009 | 04:01 AM
Empire05's Avatar
Empire05
Hey what did you mean by you got a piaa kit and put hids in those?
thanks again for the help
Old Dec 17, 2009 | 08:48 AM
Retrosolutions
Former Sponsor
The stock bulbs are 55W halogen
thanks!!
Fogs are meant to be a wide foreground pattern, not for distance, so 35w would suffice and keep everything the same as the other set, but you can use either there.
Then they are blinding people since there is nothing to stop light emitting through the top of the bulbs. Its simple physics really, at night pupils will constrict and due to the contrast it will limit other drivers visibility.
