Grill Removal
Old Sep 27, 2007 | 07:20 PM
smythge's Avatar
smythge
Default Grill Removal
There must be a trick in popping those annoying tabs to remove the grill I can't even begin to get my hands in there. I can get at the top tabs but they seem flimsy like I am going to break them. Any help is appreciated.
Old Sep 27, 2007 | 08:01 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Default RE: Grill Removal
Short pair of plyers.
Also, remove the two 10mm bolts that holds the bumber by the head lamps. You'll have more room to stick your hands in there.
Old Sep 28, 2007 | 09:15 AM
157dB's Avatar
157dB
Cut & Paste Expert
Remove 10mm bolts (2), andwork at the sides first and attack the bottom
clips from under the car avoiding damaging the A/C condenser using a helper.
Small screwdriver placed properly pops them right out
Old Sep 28, 2007 | 02:55 PM
BLD06GTVert's Avatar
BLD06GTVert
I used 2 screwdrivers to do it the other night. One screwdriver sorta wedged into the slot where the tab goes thru and the other one to pull the tab thru. Definitely takes some finesse.
Old Sep 28, 2007 | 04:15 PM
A_J's Avatar
A_J
When I did mine I went ahead and removed the whole front bumper cover/fascia (I was replacing the lower grille too at the time), and was glad I did - it saved much frustration with those tabs.. removing it isn't too bad, remove inner fenderwells, two screws in each wheelwell, those two bolts on top, and a few underneath. With it off, I was able to undo the tabs without any marring.
Old Sep 28, 2007 | 04:18 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
Yea I went through and just popped it off with a screw driver, but this was with the bumper cover off.
Old Sep 28, 2007 | 06:16 PM
06roushv6's Avatar
06roushv6
yeah, the tabs can be a pain, but with a scewdriver and some pliers, should be a piece of cake
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
