Crap... Jacked in the wrong spot
Well I was tryin to rotate my tires and I guess I didn't know what I was doing... all of a sudden I started smelling gas, and realized I must have put the jack in the wrong spot. A little fuel leaked out... it doesn't look like more leaking is occuring. I haven't tried to turn the car back on yet.
What should I do?
What should I do?
Did you examine the area where the jack was at? Exactly where was it? Did you pinch a line, filter, or filler neck. If you saw fuel, I'd investigate completely. Have any pictures of the area affected? It's hard to say much without seeing anything.
It was right under the driver side door I will take pics as soon as I can
edit:
My plan is to tow the car in the morning to Supertune my local shop... I don't know how expensive it will be to fix.
edit:
