2008 Trunk Release - Pick a Wire Bundle!
Old Sep 19, 2009 | 03:47 PM
HypromanGT's Avatar
HypromanGT
Question 2008 Trunk Release - Pick a Wire Bundle!
I'm trying to do the trunk release button mod and I'm getting *really* frustrated at this point. I've spent considerable time on this and other forums looking for more specific details on WHICH wiring harness to look for this stupid white/pink wire, but the best I can come up with is "the large wiring harness". Well, I may be dense, but there's about 6 bundles of wires in there, some heading into the SJB, some going out, and I think I've found 4 different wires that *might* fit the bill. I've tried one already with no luck, and I would rather not cut into another one unless I know for sure it's going to be the one. To top it off, the wire at the trunk isn't even white/pink, and seems to be cold unless the fob button is pressed. It seems counter-intuitive to be grounding out this wire for latch activation (I am using the grounded momentary switch technique, as opposed to the
Anyway, I have taken a few pictures and circled/numbered all the bundles I could find. Can someone please please please tell me which picture/number I need to be looking at?
Thanks a ton.
The forum is killing the detail of the pics. Please use the links below for the higher-res ones:
ftp://hyproman.serveftp.net/car_pics...B_Wiring_1.jpg
ftp://hyproman.serveftp.net/car_pics...B_Wiring_2.jpg
ftp://hyproman.serveftp.net/car_pics...B_Wiring_3.jpg
Attached Thumbnails 2008 Trunk Release - Pick a Wire Bundle!-sjb_wiring_1.jpg   2008 Trunk Release - Pick a Wire Bundle!-sjb_wiring_2.jpg   2008 Trunk Release - Pick a Wire Bundle!-sjb_wiring_3.jpg
Old Sep 20, 2009 | 01:32 AM
Johnboy7701's Avatar
Johnboy7701
Hey man I looked for my instructions I used but to no prevail I cant find them. The wires I used were under the passenger side door sill. You need to remove a couple panels to get that to come off and use a ground in behind the glove box and run the power wire to the bundle under the door sill.... hope this helps and you'll have to tear up some electrical tape to find the correct piink and white wire... hope this helps ....
Old Sep 20, 2009 | 09:17 AM
HappyTrails's Avatar
HappyTrails
Although I have not personnally done this, I saved the following link for future reference.
http://www.cherod.com/mustang/HowTo/TrunkRelease.htm
Old Sep 20, 2009 | 12:54 PM
degeze's Avatar
degeze
I have added the trunk release button and my wire was found in area 6 on the first pic. I tapped there but ran the wire to my button on the drivers side here...
Old Sep 20, 2009 | 04:22 PM
HypromanGT's Avatar
HypromanGT
Thanks! That did the trick. I was looking too far forward (in the giant bundle of wires). It's funny that you happened to have the answer; your previous post/pic inspired me to put the button in the same location you used.
Works marvelously now, thanks everyone!
Old Sep 20, 2009 | 05:49 PM
degeze's Avatar
degeze
Glad I could help.
Old Feb 28, 2012 | 10:12 PM
Chicagogt85's Avatar
Chicagogt85
Hello my wiring harmess doesn't have a white with a pink strip but 2 white with a yellows. Any thoughts
Old Feb 29, 2012 | 07:31 PM
ironh19's Avatar
ironh19
when I installed mine I just popped up the passenger side door sill and got the little pink and white wire from there, worked lieka charm
movielover40
Sep 15, 2015 10:37 AM
rocky321
Sep 15, 2015 10:00 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 04:12 PM
