Sponsored by:
Sponsored by:
Steeda and Koni installed....
Old 05-09-2010, 09:07 PM
Roy_R
Roy_R's Avatar
Default Steeda and Koni installed....
Finally had time to install the Koni's and the Steeda Sport springs. Also installed the Steeda HD Strut mounts...
Car is solid and the drive is perfect. I like the stance too, still has the Mustang aggressive look with the tail a bit higher. Drop is 1" in the front and 1.25" in the rear...
Jack in position
Removing the torque bar
Securing the wheel assembly
Old strut assembly removed
Koni's installed
HD Strut Mounts, top side
Love the way it sits
Front wheel
Rear wheel
Roy_R is offline
Old 05-09-2010, 09:26 PM
Tylus
Tylus's Avatar
very nice looking
do you have any side shots that show the front/rear gaps?
and mind posting the part #'s for what you used?
Tylus is offline
Old 05-09-2010, 09:37 PM
legendlime05
legendlime05's Avatar
now go have fun and put that stang in the twisties
legendlime05 is offline
Old 05-09-2010, 10:04 PM
Roy_R
Roy_R's Avatar
Koni Springs STR.T - Street (Orange):
http://www.stranoparts.com/
Steeda Sport Springs:
http://www.steeda.com/products/steed...springs_05.php
Steeda Heavy Duty Upper Strut Mounts:
http://www.steeda.com/products/heavy...nts_street.php
Not the best picture, but you get the idea....I wish the wheels was 1" more offset. That will fill the gap nicely.
Roy_R is offline
Old 05-10-2010, 06:49 AM
Trez83
Trez83's Avatar
That sits perfectly! Now I know what set up I'm going to do.
Trez83 is offline
Old 05-10-2010, 07:55 AM
deekum1627
deekum1627's Avatar
looks bad *** man, nice job. i just did the same setup only i used gt500 strut mounts and eibach pro kit. and ur right it drives great it def somethign i should of done sooner.
deekum1627 is offline
Old 05-10-2010, 10:12 AM
Roy_R
Roy_R's Avatar
The springs are stiffer than OEM, but not so bad that your fillings fall out of your mouth. I did take it around a 90 degree corner at about 90mph, both front and rear tires got loose, but the power slide was very well balanced and controllable
PS. We have thank Sam Strano, he's the one who recommended this setup!
Roy_R is offline
Old 05-10-2010, 07:03 PM
Tylus
Tylus's Avatar
thanks for the info. bookmarked this for when I'm ordering stuff.
Tylus is offline
Old 05-10-2010, 07:47 PM
Roy_R
Roy_R's Avatar
As far as tools are concerned....had to use a 19mm socket on the strut compressing clamps.
Sockets 10mm, 13mm, 15mm and 18mm.
Socket Wrench
Torque Wrench (up 150lbs)
Wrench - 9mm, 18mm (not sure on the 9mm, used to hold the strut shaft)
Floor Jack
Jack Stands (x2)
PS. Not sure how to torque the bolt on the top of the strut. I used a shifting wrench on it, think it may be 20mm or 21mm.
Roy_R is offline
Old 05-15-2010, 06:02 PM
07blkgt62
07blkgt62's Avatar
Looks very nice, congrats.
07blkgt62 is offline
Quick Reply: Steeda and Koni installed....
