Convertible top getting caught
Old Feb 28, 2006 | 10:28 AM
demarcom's Avatar
demarcom
Default Convertible top getting caught
Anyone with a convertible have the inside liner of the top get caught up on the outer sides of the back seat plasctic area? I have resorted to getting out of the car and guiding the top liner so it doesnt get caught. Seems like it's going to rip if you just force it back with the electric switch.
Old Feb 28, 2006 | 11:07 AM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
Default RE: Convertible top getting caught
Mine scrunches up pretty good, but doesn't actually seem to get caught in anyway.
I would advise having your dealership look at it if your that concerned.
Old Feb 28, 2006 | 04:36 PM
ChewbaccaD's Avatar
ChewbaccaD
No problems with mine here either... you should probably get that checked out.
Old Feb 28, 2006 | 05:08 PM
Furinox's Avatar
Furinox
only thing i've noticed with my top that I dont quite like is that in cold weather it moves SOOOOOOO slow. I was working on the car when it was about 35ish degrees and the top took quite a while to put back and then up again.
Old Feb 28, 2006 | 06:27 PM
ScottRNelson's Avatar
ScottRNelson
The only problem I've had with my convertible top is that after putting it up, there is still a gap of about two inches on the left side and I have to pull quite hard to get it to latch. I had hoped that with time the car would get better, but it's been doing it since last June and I'm not seeing any real improvement.
Still, I would rather live with the problem than take a chance of someone screwing things up trying to fix it. Besides, after it stops raining in a couple of more months I won't be putting the top up anyway.
Old Feb 28, 2006 | 09:14 PM
austijc's Avatar
austijc
ORIGINAL: ScottRNelson
There's a TSB that sounds like that. The solution is to check the hydraulics and then replace the side rails if needed.
Old Feb 28, 2006 | 09:44 PM
Hambone's Avatar
Hambone
ORIGINAL: demarcom
Yeah, mine catches there but it does seem to slip by it. I've noticed some lines there...I'm keeping an eye on it,that's for sure! But I've not felt the need to get out and help it....yet.
chrisdbassplayer
Oct 13, 2015 06:53 PM
b8checker
Sep 30, 2015 07:11 AM
treesloth
Sep 28, 2015 07:03 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
