Hellwig Anti-Sway Bar Pics!
Just came in UPS
here are pics of the rear Anti-Sway... it is 1" and is quite heavy. $150 from the Group buy... comes with all hardware as you can see... The part is the #6805... I will get on the car next week and take pics... darn those plans already in place for the weekend!
[IMG]local://upfiles/26988/90655BD7F7B94E48BBE37C0127D818B2.jpg[/IMG]
[IMG]local://upfiles/26988/CA3696DBF1C34BB7A6625FFA67BE9188.jpg[/IMG]
[IMG]local://upfiles/26988/BC93369BB0484BA9843780CEA4EF2C39.jpg[/IMG]
here are pics of the rear Anti-Sway... it is 1" and is quite heavy. $150 from the Group buy... comes with all hardware as you can see... The part is the #6805... I will get on the car next week and take pics... darn those plans already in place for the weekend![IMG]local://upfiles/26988/90655BD7F7B94E48BBE37C0127D818B2.jpg[/IMG]
ORIGINAL: Truxtun
Just came in UPS
Just came in UPS
It was a group buy back in Sept, '05... I found the link while searching Google... I called Nancy to see if we could still get the Group buy price and she said yes!... so if you would like a set... give Nancy a call and she will set you up... $110 for the front and $150 for the back... and as you can see they come with everything you need to install.
I will take pics next week when put on the car.
Link for the phone number is https://mustangforums.com/m_1087249/tm.htm
Nancy can be reached at 800-367-5480, I also told her to expect more calls from the Mustang Forums
I will take pics next week when put on the car.Link for the phone number is https://mustangforums.com/m_1087249/tm.htm
ORIGINAL: Exotic_HP
Let us know if it improve your launch?
http://en.wikipedia.org/wiki/Sway_bar
ORIGINAL: fin1
Sway bars add no value to your launch. It's used in corning situations only.
ORIGINAL: Exotic_HP
Pricing is still good... give Nancy a call. For the V6 there is no rear anti-sway (might be on the Pony package in '06) and for the GT's it would allow you to adjust the rear (with 2 holes) and the front (with 3 holes) also both the front and rear from Hellwig the bars are solid heat formed, stock from Ford are hollow.
I just received mine, I will install this week, and should take about 2 hours total, comes with ALL hardware needed, and the mounting location for the V6's are already there. I will take pics. Will not need to realign, as the anti-sway is to reduce body roll and should not effect the alignment.
