high speed handling
Old Mar 16, 2006 | 07:10 PM
lost in kuwait's Avatar
lost in kuwait
Default high speed handling
is their any body out thier that can tell me how to take some of the boost off my power steering pump on an 05 gt here in kuwait we travel at terminal speed and the car is to touchy over 125 mph any help please.
Old Mar 16, 2006 | 09:32 PM
Sleeper05's Avatar
Sleeper05
Default RE: high speed handling
a)lower it
b)get stickier tires
messing with the power steering is just gonna lead to problems with everything...make it perform better and reap the benefits of that on top of better high speed handling
Old Mar 16, 2006 | 09:46 PM
chrisc's Avatar
chrisc
lowering it is going to help a lot
Old Mar 17, 2006 | 01:00 AM
Big Red's Avatar
Big Red
ORIGINAL: lost in kuwait
I wanna go to kuwait... [8D]
Old Mar 17, 2006 | 01:29 AM
Thetics's Avatar
Thetics
racing stripes and decals
Old Mar 17, 2006 | 01:52 AM
Kriger's Avatar
Kriger
what about air pressure and letting some out of the front tires? and what speed are the tires rated at? You could disconnect the power steering and go without it... lol but thats rough on a car that weight with those size tires... It'd be easy at high speeds but at slow speeds you'd have to have pretty big arms to turn the wheel.
Old Mar 17, 2006 | 06:02 AM
saud alzaabi's Avatar
saud alzaabi
u should lower it and get better tires .... change the wing if possible it will help the rear end stick to the ground.
ORIGINAL: Thetics
hahahaha yeah thats gonna help alot.....
Old Mar 17, 2006 | 08:59 AM
grasshopper's Avatar
grasshopper
Have the front alignment done and get the toe-in set at the maximum within the factory spec range. If that's not enough, you can adjust it yourself at the tierod end by loosening the jam nut, then rotate the shaft so that the rod end is being screwed onto the shaft. Only turn the shaft 1/4-1/2 turn.
This will essentially cause the car to resist your inputs slightly. At high speeds you'll have to turn the wheel further for the same turning rate, and at low speeds it will want to push in the corners.
Tires and lowering will most likely make it dartier at high speeds since the tires will likely have stiffer sidewalls and there will be less energy lost to useless body motion from the tighter springs.
Old Mar 17, 2006 | 02:23 PM
Thetics's Avatar
Thetics
dont forget the cobra badge.
Old Mar 17, 2006 | 02:58 PM
Secter's Avatar
Secter
ORIGINAL: Thetics
Yea, my ricer friend claims each decal and badge adds 5 hp
