question about centre console
Old Apr 4, 2006 | 07:39 PM
Treatz's Avatar
Treatz
Default question about centre console
Hey everyone.
I went to the Ford dealer to ask about this, but they said nothing is there so I wanted to check with the community.
1>in the centre console, by the front closest to the shifter there are 3 circles. It almosyt looks like a change holder but that's not it. Is there a cup holder or some type of slide in piece that goes there?
2>what's the plugged up hole there for as well
closest to the driver. it has a cap on it but you can easily remove this exposing a hole.. is this for another option or something?
Old Apr 4, 2006 | 07:43 PM
Menace's Avatar
Menace
Default RE: question about centre console
Inside the actual console there is slots for change, and also there is a charger port... To put in like a phone charger, or any of those electronics that use that type of outlet. If you are referring to the plugged hole in the center of your buttons, where it has your TCS and all that... Then that is aanother charger outlet.
Old Apr 4, 2006 | 07:45 PM
LisaJ429's Avatar
LisaJ429
the three holes you are talking about are for holding change.
the one closer to the driver - i have no idea what that is for.
Old Apr 4, 2006 | 08:34 PM
Treatz's Avatar
Treatz
i figured it was for change but i wasn't sure
Here's a pic of the other thing i'm talking about
you can see a plastic plate is covering another hole
Old Apr 4, 2006 | 08:42 PM
Philostang's Avatar
Philostang
Hey Treatz,
I pulled that up when I first got my car--if memory serves me well, it is just an access plate to get at a bolt under there. Nothing special. BTW, getting it back in is tricky due to the angle it has to come in at to clear the lip under the plate.
Best,
-j
Old Apr 4, 2006 | 09:20 PM
tncruiser's Avatar
tncruiser
that 1/4 in slot next to the shifter is a release button if your brake to shift out of park function fails, it will allow yuo to get the car in gear by using a thin screwdriver or an extra key. I THINK
Old Apr 5, 2006 | 12:19 AM
2K5 Legend's Avatar
2K5 Legend
the covered hole is for accessing your parking brake cable for adjustments.
Old Apr 5, 2006 | 12:22 AM
SpecterGT260's Avatar
SpecterGT260
centre? WELL BLOODY CHEERS! [sm=icon_cheers.gif]
Old Apr 5, 2006 | 06:12 AM
mongrull006's Avatar
mongrull006
the hole is to access parking brake adjustment nut, no big deal really
the slots, well they are change slots as far as i know, i just cant figue out why there isnt 4 of them little buggers. but if there is something special about those slots i wanna know...
Old Apr 5, 2006 | 06:57 AM
grasshopper's Avatar
grasshopper
The slot closest to the passenger holds both pennies and dimes.
My only problem is I haven't figured out how to put change in them without dropping it all in bottom of the bin first.
