Having clutch problems
Old Apr 18, 2006 | 12:20 AM
Mustangpower5's Avatar
Mustangpower5
Default Having clutch problems
I replaced my stock clutch with a Hays Street/Strip 11-inch clutch kit and after installing it worked perfectly and after two days of use i cant engage any of the gears...i only have no more than 75 miles on this new clutch, the weird thing is that after doing a burn out it helps out in engaging the gears, the gears wont go in easy but at least they will go in. I NEED HELP
Old Apr 18, 2006 | 09:29 AM
QuickShortBus's Avatar
QuickShortBus
I ♥ Acer
Default RE: Having clutch problems
Did you buy a clutch that is made specifically for an 05+ Mustang? If not the throwout bearing needs to be shimmed.
Old Apr 18, 2006 | 11:29 AM
rex7010's Avatar
rex7010
Why did you replace your original clutch for..?? worn out..??
Rex
Old Apr 27, 2006 | 03:23 AM
Mustangpower5
I had it checked out...i didnt break it in, supposedly after installing a new clutch, you shouldnt be racing until you put some miles on it. The first day i put on the clutch i went drag racing and the pressure plate went bad. Now i know you need to break in clutches when installed.
Old Apr 28, 2006 | 01:09 AM
PonyGT2005's Avatar
PonyGT2005
Yep...most clutches require a break in period...from my knowledge that's usually a 300-500 "normal" use driving period....no burnouts, speed shifts etc. I recall some Stage 3+ clutch that was advertised as not requiring a break in period but can't recall the mfr.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
