For anyone with an E H2O pump
I have been looking at one of these things and I have a Q to anyone that may know. The Mezzerie pump has a pulley built in so the serpentine belt stays in place. Does the pulley come on it or do you use the factory one? Every picture shows a pulley on it. Just wondering what to expect. Thanks
RE: For anyone with an E H2O pump
it is a part of the new pump and has no load on it other than its own miniscules rotational mass. with the pump, there is no reason for a water pump pulley if you want underdrive pullies as well because you only need the crank harmonic balancer pulley
ORIGINAL: The Ghost I have been looking at one of these things and I have a Q to anyone that may know. The Mezzerie pump has a pulley built in so the serpentine belt stays in place. Does the pulley come on it or do you use the factory one? Every picture shows a pulley on it. Just wondering what to expect. Thanks http://www.brenspeed.com/mustang_200...p346steeda.gif |
Thanks Sleeper and Suad....but that was part of the reason for the Q. I do have UDP's and was wondering what I am going to do with the water pump pulley now. E H2O pumps are very safe, but I would look into a relay that would shut down the motor if the pump fails, probably a presure switch that would defeat the fuel pump. That would make it actually safer than a standard H2O pump because I don't believe the motor will quit if no flow is detected. Of course this car seems smarter than me so it might.
The trick is to keep an eye on your dash, there's a coolant thermometer for a reason. (I've glance at it often since my waterpump failed on my aspen 10 years ago, lol) |
ORIGINAL: The Ghost Thanks Sleeper and Suad....but that was part of the reason for the Q. I do have UDP's and was wondering what I am going to do with the water pump pulley now. E H2O pumps are very safe, but I would look into a relay that would shut down the motor if the pump fails, probably a presure switch that would defeat the fuel pump. That would make it actually safer than a standard H2O pump because I don't believe the motor will quit if no flow is detected. It would be easier to put a temperature switch in that would trip at a specified temp shutting the motor down or just put a warning light in like Autometer offers and when it lights up shut the engine down. |
ORIGINAL: Tik_Tok The trick is to keep an eye on your dash, there's a coolant thermometer for a reason. (I've glance at it often since my waterpump failed on my aspen 10 years ago, lol) |
Stock temp gauge stinks....presure is 18-22psi....that's when the radiator cap blows off to relieve presure. At 55 GPM even dead cold it should build 3-5 psi. maybe more. So on that note, you are right a presure switch will be too difficult due to having to have a high and low range. A high temp shut off would be better, just thinking now (smell of wood burning)....I tend to do a lot of that before I actually come up with something that suits me. I hate doing things twice or incomplete. Thanks all for the input.
I like the high temp cutoff, I may have to do something similar on my car when I do an E-H2O pump.
