10 Second '05 Saleen
I have the c-4 in the car with a two step and transbrake. Great trans, it robs some h/p but it is super consistent. My front struts are the Santhuff '05 replacement. They are awesome and work really good on the car. Pricey but worth every penny.
Nice car but I'm sure your aware that better numbers have been seen by many without stripping it down. Justin Burcham ran in the 9's with virtually nothing stripped stock motor, powerhouse ran in the low 10's with virtually nothing stripped stock motor, vortech ran in the low 10's with virtually nothing stripped stock motor, etc, etc.
It is actually pretty easy to get in the low 10's on the stock motor - the trick is STAYING in the low 10's on the stock motor. I run in the low 11's on the stock motor with no weight reduction what-so-ever with a daily driver and have done so over 100 passes in the last year. You are making great times with the Saleen, there's no denying that and I commend you, but if you can do it for 50+ passes, then I'll be impressed. I'm suprised you didn't go with an 8 rib pulley set-up to help with the belt slip in high psi range.
Anyhow, congrats and I'm sure we'll see great things from you guys.
In terms of an 8 rib setup, that is not stock. So therefore I chose not to go that route. As of right now the belt does not slip on acceleration, only on lift.
100 passes on the stock motor is something to be proud of. Hopefully I will make it that far!!!
I haven't looked at the trans a lot, how did you get around the speed sensor? Does the stock sender fit the C4's speedo cable location?
ORIGINAL: kss3valve
Sorry guys, but I have to clarify one thing......... The motor in the car is OEM stock. KSS does not have the fastest mustang by far or the shiniest or pretiest or whatever........ We went in a different direction than anybody else, we converted the car to a race car to see how fast of an ET we could get the stock motor down to. Justin Bircham is the man! He was the first in the tens, first in the nines. He deserves all the respect that I can give him. His nine second pass really woke people up, however it was with a built motor. We are not in the same class as the other guys with turbos and nitrous and prochargers. When we have changed from OEM to a whipple, then we have a modified motor.
And thanks for the koodos - but it is a matter of WHEN not IF for all of us pushing the envelope. I'm currently building a 302 stroker and going with an art carr 4 speed AOD with trans brake and tuner. I would LOVE to see some video of your runs....
Yup, its gonna blow big!! Here are the specs.......
frpp matched 39lb injectors with cpr fuel rails, converted to return style.
JDM Upper pulley
Innovators west crank
mixmatched ford 6-rib pulleys
custom tensioner and a/c delete
extended bypass valve arm to clear fuel rails
-8 fuel lines
c&L racers pipe
Predator and MaFia
JDM Upper pulley
-8 fuel lines
c&L racers pipe
Predator and MaFia
ORIGINAL: kss3valve
JDM Upper pulley
-8 fuel lines
c&L racers pipe
Predator and MaFia
JDM Upper pulley
-8 fuel lines
c&L racers pipe
Predator and MaFia
EDIT - and VERY impressed if you are still on a single fuel pump without the KB boost-a-pump.
Now that makes a lot sense...thank you. Fuel issues are always the toughest part of my builds. best of luck and I'm sure we'll be seeing awesome things from you guys...
Weldon racing fuel pump turned up to 62psi at idle. air fuel curve is 11.8-1 right accross the board. 5-galllon intercooler cell and fuel cell in the trunk.
