New GT....License plate brackets missing??
I got my plates in the mail the other day from the dealer because they are like 90 minutes away. Went to install them today and I realized that there are no plate brackets on the car.
Is there supposed to be any?? The dealer's plates were just screwed onto the body.
As it stands now, the front and rear plate would just tighten against the paint on the car and scratch the crap out of it. Most other cars have brackets to stand the plate off the body a bit to prevent damage and vibration.
Are mine missing or is this a design flaw??
I put some rubber washers under the back plate to space it out a bit and keep it off the paint for now. I just threw the front plate in the trunk for now until I figure it out. I havent decided whether to run a front plate or not yet anyway.
So am I missing parts guys, or what?
Thanks,
Nick
Thanks,
Nick
Nope your not missing anything. I discovered the same thing a few days ago and removed the dealer plate frame for that reason you mentioned. Like you I plan on sticking some rubber washers behind it once i get my plates. As for the front it is suppose to be the exact same way and I do not plan on installing a plate until it becomes and issue with a ticket. I did see someone on Ebay selling a temp front bracket mount that could be easily installed and removed for getting fix it tickets signed off.
Richard
Richard
Yup, this is one thing FORD screwed up. The majority of states don't require a front, so FORD didn't consider that. The front plate really screws up the look of the car. and...... I agree, run, until it becomes an issue.
Tacky, as this may seem, I've thought about putting the fr pl on the passenger visor with rubber bands, rather than driil holes in the bumper.
There are alot of brackets available, just shop around for something you like.
FRONT PLATES suck
FRONT PLATES suck
Thanks.
Just seems so cheesy.
As far as the front plate. Two trains of thought with that. Either a cop will give you a ticket for that in liu of a speeding ticket. OR, they will pull you over because of that and give you a ticket for both.
I have heard of both happening at about equal frequency. So who knows. Maybe I will try running without one for a while. Whats the fine, $50.00 usually?
Carry around your front plate with double sided adhesive tape on the back. Get it all dirtyish looking and used, and plenty of crud on the double sided tape, maybe stick it to something and rip it off. Bend a lower corner of if. Then next time you are pulled over and they say "no front plate eh?" -- Pull it out and say that it was falling off at the last stop you made and you didn't want it to be a hazard to other motorists if it fell off on the highway. Works every time.
Problem is that the car I found already has the holes drilled for the plate so unless I just say the bracket is missing or broke, the holes are there for the plate.
Wierd, every other dealer I was at left the front plate off all their Gt's in stock. My luck, I find the perfect car, and it already has the holes drilled on the lot.
Took me a while to realize that the V6 cars all have a plate recess and the GT doesent.
ORIGINAL: praztek
That'll work, unless you get pulled over twice by the same police officer!
