Zex Nitrous Question?
You can do that with any nitrous system.
Basically, the system is just a simple circuit. When the circuit is closed ("switched on") it opens the Nitrous and Fuel solenoids, and you spray.
However, practically speaking it is not a wise idea to leave out the WOT switch. Nitrous is unsafe to run outside of WOT. On a typical, well-done, install you will have several switches wired in series in the nitrous circuit:
WOT switch: Allows the system to spray only when you are at WOT.
Fuel pressure switch: Shuts off the NOS if your fuel pressure drops (this can save your motor)
Safety Switch ("Arm" switch)--prevents accidental use of your system. Some people use a hidden or key-lock switch to prevent someone else from using your NOS if they are driving your car.
If you like you can add a "spray" button--that sprays nitrous when you push it--but it should be used IN ADDITION to the above, not in place of any of them.
cool deal, very informative. Im new to the Nitrous game.
the only reason I was considering a spray switch was because I really dont want to tap into my throttle posistion wire.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
